Question about Kodak ESP 5 Printer
2nd black cartridge installed only prints when first switched on
Our group bought one of these printers to use on a Saturday. It is about six months old and I have just changed the cartridges for the first time. It not taken out of cupboard every Saturday. Before I replaced the cartridges the black was not printing properly. Since both cartridges were replaced the black cartridge will only it will only work immediately after being switched on. This presumably is because the print head has been charged up. When the printer is left for a few minutes the next page that is printed is streaky. By the time the 4th page is being printed it is virtually blank unless it has a colour image because there is no problem with the colour cartridge. Last week I printed about 50 sheets then left it alone for a little while. The poor quality printing when I came back to it left me very frustrated.
Susan
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
HP 4315 not printing from black cartridge. Stored for six months since last used. Replaced black cartridge & ran alignment and cleaning programs. No success.
when you store a printer for that long a time it the lines that carry the iink dry up. There is a procedure that is in user manual that you can do to possible clear the problem. It's called cartridge cleaning procedure
Feb 19, 2011 | Office Equipment & Supplies
My Epson 1400 is printing blacks green. After gray 40 % all my gray and black is coming out green. what can I do to solve that, and please don't tell me to chane my printer I just boughted it 4 months ago.
The printer is using your color cartridge to print black and greys.
The black cartridge must be empty and will need to be replaced.
The color cartridge has depleted one of the primary colors required
to print black.
Both cartridges will need to be replaced
Feb 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer will not print
This is the common problem of all brands of inkjet printers friend. You should atlease power on and off weekly once every inkjet printer. Otherwise the inkjet cartridges may claute.Call Epson service people they will come and clear it. Dont clean your cartridges yourself and waste valuable inks.
Aug 09, 2009 | Office Equipment & Supplies
How to use only black cartridge on cx7450 epson !
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP Deskjet 3820 Won't print blue
The problem is most likely an "old" cartridge, even if it was new in the box. Printed on the box is an "install by" date which is 18 months from the manufacture date. If you do not have the box you can check the warranty date on the cartridge as shown here. The warranty date is two years from the date of manuacture, six months beyond the "install by" date.
A fresh cartridge will almost certainly solve your problem. When buying new cartridges I would look for at least six months remaining before the "install by" date.
When storing cartridges for long periods keep them in a cool place and leave them standing upright as they would be hanging on a store display shelf for maximum life.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Aug 01, 2008 | HP DeskJet 3820 InkJet Printer
My hp 2600n color laserjet leaves RED DOTS on the printed document. What should I Do?
look at the red cartridge do you see any dots on it ? is it only when you print? what about if it's just Blk & wht?
Jul 21, 2008 | Sharp AR-5320 Black and White Copier
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
Kodak ESP 5 Printer Logo
126 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
