Question about Emerson ET-20F7 19" TV
Turn video off
I don't have the remote to my tv and I can't get video off. How do I do this?
  • smr13722 Aug 15, 2008
    I have the same problem with the emerson.  My daugter threw the remote in the toilet and it will not switch to game mode now.  This is a problem, the kids cannot play their playstation.
Cant switch to video
Posted on Dec 13, 2007
I don't have a remote for my tv. How do I get the tv back to tv/video?
If your TV has a 'Menu' button at its front panel, you can surf through its menus and can set the input select option to make it into tV/Video option. If there is no such button, no other way to select the input selection without its remote control.
Jan 05, 2013 | Toshiba Televison & Video
Norcent dvd home theater plays good sound, but no picture
check that ur video input on the tv is set correctly. you can do this by turning on ur theater system first , when u get ur sound grab the tv remote and select the tv input button or if u don't have said button try thr tv/video button untill u get a picture. ( this of course a suring that ur video cable is connected ) hope that helps
Jun 03, 2012 | Norcent Technologies DP-2700 System
When i turns off video for to get the channel 3 back aucan signal comes up how would i get back to the channel 3 to watch tv
If your DISH remote is programmed to operate your TV, you can press the TV button at the top of the remote and release it. On the number pad, press the number 3. If you get a picture, press the SAT button on release it. You can now operate your satellite receiver.
If you don't get a picture, use the TV remote to place the TV on channel 3 or you can use the channel button on your TV.
Aug 06, 2011 | DISH Network 625 Duo DVR Receiver...
I have a Magnavox 15MF605T 17 that when the power button is pushed it goes green for a couple of seconds then turns amber. No picture, sound, etc. I unplugged the TV for about 10 minutes and when I...
Try to turn it on with a remote if one is available. If you don't have the original remote you can look up the universal code for the cable or satellite remote. Also try to turn it on with the input source(vcr,video game, cable box,etc...) on first. I have the same TV and if it has no signal prior to manual power up it will go to standby mode.
Jul 08, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
May 13, 2011 | Televison & Video
Purchased an RCA universal remote (RCRH02B) and the codes listed in instructions don't work. After programing (or trying) the device with all the codes individually, the TV will turn on and off,...
Consider that you may have a bad remote. You never mentioned why you bought a new remote. Did the original remote quit working? If so, the problem may be with the TV.
Jan 04, 2018 | Toshiba 13A24 13" TV
I'm trying to connect my Wii console to an old magnavox tv my aunt gave me. I don't know how to connect it because it doesn't have the tv/video button on it. I've tried reconnecting...
U have the tv original remote?Look for a button said Input,used that button push it to goes into video mode 1 or 2.Don't have the tv original reomote.Try website like to buy the tv original remote.
May 08, 2011 | Televison & Video
Zenith TV
have u tried using a universal remote and programming it for your tv? sometimes universal remotes can break a code that a common tv remote cant, hope this helps, just a suggestion!!!!
Dec 28, 2007 | Televison & Video
Can,t be able to turn my tv set to video mode
try some universal remote controls!
Dec 05, 2007 | Televison & Video
Televison & Video Logo
102 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
