Question about Sport & Outdoor - Others
I have a 1986 johnson 2 stroke that has just been rebuilt a year or so ago. compression is good and all cylinders firing. we go out on the lake...it will run fine for awhile and then all of a sudden it will lose rpm, doesn't shut completely off, but kicks down to about 1.5 rpm, sometimes will take off again, and sometimes will not go any faster. We have had it serviced many times..with new spark plug wires, new stator coil, new wiring and still doing the same thing. Please tell me what you think. thank you
  • 1 more comment
  • gaucli Sep 09, 2009
    it is sparking on all cylinders.
    well it seems like when it heats up it runs a little better. do you possibly think that one or both of the power packs are bad...and do you know if there is a way to check to see if they are bad?
    i hope this works...thanks
    President:
  • 1,884 Answers
Everything seems to be new in your motor. have you cleaned or serviced the air filters as well? or may be gasket is going. when the engine heats up gradually, it starts leaking. thus reducing the power and rpm. but 1.5 rpm is ridiculously low.
Posted on Sep 09, 2009
  • Vinay Tevatia
    Vinay Tevatia Sep 09, 2009
    Gaucli,
    It is very difficult to findout is the gsket is indeed gone or going. Only symptoms can indicate. Alternatively, when the motor starts going into depression, move your hand aroung the engine to see if you get the hot air blast. Dont go too close to it else you may injure yourself. have you checked up the air filters?
  • 6,674 Answers
First of all I don't claim to be an expert in 2 stroke boat engines but I will ask this much, do you mix the oil or is it injected, and have you ever thought of shutting it down & pulling spark plug to have a look at it when this occurs?
Hi, when sitting on my 1986 cb700 nighthawk do the cylinder numbers start from left to right as 1234 and does left coil go to 1 & 4 and right coil to 2 & 3 ? Many thanks. Brian
The coil with the yellow lead from the pulser supplies sparks to the inboard cylinders. The coil with the blue lead supplies sparks to the outboard cylinders. That is all the rules needed, as the coils fire both cylinders though one is on the compression stroke while the other is on the exhaust stroke.
Jun 25, 2017 | Cars & Trucks
My boat motor Johnson 90 hp will not rev up throttle is wide open have checked coils fuel pump new spark plugs. all good boat sank a few years back. before that ran great.it is a 1986 unit
it sank..ooopppsss...sounds like trouble.. First thing I would do is check the compression with a gauge... This will require a GREAT friend.. remove all the spark plugs - makes PULLING the engine over easier.. get a compression gauge (or take it to a competent professional to get the compression checked!). Install the compression gauge... Put the throttle wide open... have your buddy yank with ALL his heart about 6-8 times..it should show about 115psi+ minimum..all 3 cylinders should be with 10+-psi.
If they are not at these specs minimum..you have found the issue..then try putting a little outboard oil into all three cylinders and repeat the test.. if the PSI goes way up.. you have found the issue.
Jun 11, 2017 | Johnson Boating
2001 1200 sportster cranks and backfires, carb and fuel good, could it be crank sensor?
Wasted spark system. If fuel and electrical is all good/correct it is often the case in these symptoms that motor cycle spark plugs that although looking good and firing outside of the engine are breaking down and will not fire under compression pressures on a power stroke but will fire unburned fuel on the unpressurized exhaust stroke when the plug again fires in a wasted spark ignition system and when so firing the result is a backfire, usually quite loud.
Jul 23, 2014 | 2001 Harley Davidson XL 1200 C Sportster...
Installed a rebuilt cylinder head set timming to all data and mitchells timming book wont start blowing back threw intake
Sounds like your timing is out 180 degrees. Recheck by making sure #1 piston is on the compression stroke, then retime.
Feb 28, 2012 | 1998 Isuzu Rodeo
With a firing order 1342 if the number 1 cylinder was on firing stroke what stroke will cylinders 342 be on?
assume #1 was on fire stroke...<
#2 is on exhaust stroke...>
#3 is on compression stroke...<
#4 is on power stroke...>
<=up
>=down
gotta be worth 4 thumbs......
Oct 11, 2010 | 2008 Volkswagen Jetta
Explain the four stroke cycleof a three cylinder
Is this a quiz? Each cylinder contains one piston that takes four strokes to coplete a a full cycle. the intake-down,compression-up, power-down, exhaust -up.
A two stroke has up and down only . Compression and power Now, I thik you really meant the firing order. I'm not sure but Would make sense 2-3-2?
Nov 18, 2009 | 1995 Isuzu Rodeo
Back fires under load and is sluggish at times
Have you checked the coils? It has three above the rear valve cover right?
Jun 24, 2009 | 1986 Oldsmobile Ninety Eight
How to start the firing order on the distri butator cap
Turn the #1 cylinder to top dead center, on the compression stroke. Remove the cap and see where the rotor button is pointed. This is the #1 cylinder plug wire position. Start from here, and clockwise run 1-8-4-3-6-5-7-2.
Jun 08, 2009 | 1986 Chevrolet C1500
1997 yz 125 wont start, please help
2 stroke bike are very dependent on compression. and being a bike that is 12 years old my best educated guess is that the top end needs to be rebuilt. i usually have to have the top end done on my honda about every three years.
Jan 12, 2009 | 2003 Yamaha YZ 125
Sport & Outdoor - Others Logo
19 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
