Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Ice maker door doesn't work
My Kenmore Elite Refrigerator 795.77569600
The ice maker door to drop ice out is not working. Door will not
open
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Adora freezer on the bottom not making ice
It could be a couple of things. Check to see if the bar that controls turning the ice maker on and off is in the down position. Up is off. My ice makes water line froze in the refrigerator section; no ice and no clod water. Check to see if the cold water is working in the refrigerator section. If not, turn the refrigerator section temperature to 42, keep the door open until it drops to that temp, and wait 24 hours for the water line to thaw. The water and ice maker should start working.
Jul 12, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
Freezer ices up
sound like you have a bad gasket or the door for the ice maker is stuck open.. use a flashlight and in the dark withe the door open shine the light up the door and see.. jay fl
Dec 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Right door pops open when left door closes
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Nov 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
In my freezer, there's an infrared beam positioned over the top of the ice bin. If the bin is full of ice, it blocks the beam and no ice can be made. In addition, when you open the freezer door, a small (2x3") door opens in the freezer to block the beam, again to prevent ice from being made while the door is open. Is anything blocking the path of this beam from one side of the freezer to the other?
Mar 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
213 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
