Question about Kenmore Freezers
I have a Kenmore coldspot 16 cu ft chest freezer and it DIED on us last night. No sounds nothing. Any ideas on how to check anything would greatly be appreciated. I was told my compressor died.
  • 612 Answers
It might have. Most likely you can start it again, but you will have to follow my instructions carefully. If you are willing, I'll tell you how to check it to see it it's bad and if not how to make it start again.
You will need a Ohm. meter and it will help if you know just a little about using it. If you do, gain access to the compressor. You will see where the wires go to it. The wires are connected to a piece or two that connects to your compressor. After unplugging your freezer, pull the parts off that are attached to the compressor. Now you will see three small metal pins sticking out of the compressor. Take your ohm meter, touch one lead from it to one of the pins and take the other lead and touch it to ground or somewhere on the copper tubing. If you have a reading, the compressor is grounded meaning it's bad. If yo have no reading. Take a lead and touch it to one of the pins while you are touching the other lead to another pin. It makes no difference which tow of the three your touching. If the compressor is good you should have a reading. Jot it down. Now move only one of the leads to the pin you have not touched yet. Jot that reading down if you have one. Now move the last lead you just moved and touch it back on the pin you started touching it to and move the other lead to the pin you just moved the other from. Jot that reading down. If the compressor is good, you first will have a reading each time you were to jot one down. Now look at you numbers you jotted down. The two smallest readings should add up to the largest reading if not exact it should be real close. If so, we can restart your compressor. You will need a Supco 3 in 1. You can get one from www.appliancepartsonline.com the part number is RCO410. It cost $21.95 plus shipping. The packaging will have the instructions on it. What you will do is gather all the parts that you pulled off the compressor. Cut them off. You should end up with only two wires. The 3 in 1 will have two Black wires that you will connect together with the supplied wire not. There will be three wires with ends on them coming off the 3 in 1 also. they will be White, Red and Black. Follow the color coded instructions on package. When you have completed these steps. Plug your freezer in. The compressor will start and run. The closer the numbers you added before where, most likely the longer the compressor will last.
Please rate solution.
Posted on Sep 09, 2009
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
Display reads off and it will not re adjust to anything. I have unlocked display but nothing changes the setting.
There may be a child lock enabled, refer to the owner's manual to disable this feature, otherwise check the troubleshooting section of the manual.
Dec 22, 2013 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
My kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Nov 21, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Chest freezer
Make sure you have power going to the unit. Check the thermostat for power on both sides going in and coming out. You need to give me more info. before I can suggest anything else.
Dec 23, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezers Logo
480 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
