Question about Ruud Heating & Cooling
The compressor doesn't start up unless I hit the high pressure reset button.
    Problem Solver:
  • 12 Answers
If the compressor is shutting off due to high pressure, the condenser coils may be dirty or blocked. Remove the top grill (may include fan and motor) and clean the coil fins from the inside out with a garden hose. Also cut any grass or shrubbery from around the unit. Remove any obstruction you see that may block air flow. Good air flow is crucial to keeping the high pressure down, especially in hot weather. I hope this helps!
Posted on Sep 09, 2009
How to reset low unload sump
Low unload sump. Would love to help but don't fully understand question. Gas as in air conditioning or refrigeration compressors low pressure (HP/LP) devise can be auto reset or if manual reset, will have a lever or button to push. If it happens often, you will need a refrigeration mechanic.
With an air compressor, make sure there is correct oil and at right level. Unless a big industrial type, there should only be a pressure regulator to control compressor electric motor. Nothing to reset. Good luck
Herman
Nov 15, 2015 | Air Tools & Compressors
QRS 25 air compressor will not start unless I push the reset button need to know where the reset button is
How do you know it will run if you reset the reset button? You could have a problem with the coil of the starter, pressure switch not closing and/ or overload issues. The reset is usually on the overload block. To check the coil you need a volt meter where you can measure in ohms or resistance. Remove both wires on the coil with power off !!!!!! and measure across those two terminals. If it is showing open then you have a bad coil. To check the pressure switch to the same thing across the motor and line terminal. If open with 0 psi in tank then pressure switch is bad. Last thing to check is overload block, there are normally a 95 and 96 terminal. Check for continuity across those two terminals (while power is off !!!!!). If open and the reset button is pushed then the overload block is defective.
Jul 26, 2014 | Air Tools & Compressors
My line water heater turns off after a few minutes
if u are hitting the red button and it is a heat pump hot water system it means that the unit is going out on high pressure ( the red button is a high pressure manual reset button) this could be caused by a few things could be over charged ( but unlikely if no one has touched it recently) a solenoid isnt opening or there is a blockage in one of the TX valves. if the button u are pushing isnt in the pipe work and it is on the compressor it could be an over temp switch on the compressor ( unit could be short of gas) just need a little more info to pin point the problem.
May 21, 2014 | Stiebel Eltron Water Heaters
Keeps tripping the reset button after done building up pressure, why?
Since I am not there and can't see what is happening this might just be a WAG, but when my air compressor does that, it is either the pressure has been set too high, and when it reaches the maximum rated setting it trips the over pressure switch that trips the reset button.
It has also happened when the pressure regulator whent out and did not sense the pressure that it was supposed to turn off on.
Sep 15, 2011 | Ingersoll Rand SS5L5 Ir Electric...
AC does not blow cool air. They put a new compressor in, but that did not fix problem. Now they say it is the condensor. I don't think they know.
did 'they' check the pressures on the low and high side after the compressor replacement? low pressure with a full charge on the low side would indicate a blockage. unless you had massive compressor failure (metal shavings in the lines) then most likely the condenser is O.K. the most common problem is the expansion valve sticks and doesn't allow the refrigerant to circulate fast enough to cool.
Jul 27, 2011 | Acura MDX Cars & Trucks
Compressor not coming on check red wire on compressor with test light compressor comes on pressure good high and low air cold
If the compressor came on when you were testing it with a test light, it sounds like something is wrong with your ground for your compressor, and completely the circuit through your test light.
Jul 01, 2011 | 2003 Honda Civic
Where do I find the reset button for the RHEEM 13 seer
If it is a condenser or outdoor unit heatpump you will have to take the cover off of the compressor section. There should be a high pressure reset that may be a manual reset located on the smaller copper line that leads to the compressor. If it is not here, some Rheem units locate the high pressure switch on the outside of the unit near the copper lines are welded to the unit. It will be just a button to push in.
Apr 16, 2011 | Heating & Cooling
Hi, some anknown animal bit off the reset button on my outside compressor. Where can i buy a new one? Part # I guess DBK 4B04799 or so. Thank you
If this is a RUUD unit, the reset button is for the High Pressure Switch. It cannot be replaced without refrigerant recovery and recharge. Unless it is creating a problem for you, I recommend NOT replacing it (quite expensive) until it DOES become a problem. In the meantime, continue to keep your filters and coils clean. :-)
May 27, 2010 | Ruud UAMB036 Air Conditioner
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
283 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
