Question about Kenmore 98702 Stacked Washer/Dryer
When stackable washer is in spin cycle it bangs on side of unit i checked under and all three spring legs are in place and working
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
My machine has started banging the cabinet in spin cycle. Solution?
first check that all 4 legs are level,
and if that dosent work check tat the springs are in good order....
Apr 07, 2010 | Frigidaire GLTF1670A Front Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
IT SPINS AN BANGS OUT OF CONTROL ON THE SPIN CYCLE
There are three things that can cause this problem. Here they are.
  1. Suspension spring missing or broken
  2. Tub balancing spring missing or broken
  3. All four feet not on the floor at once. (Needs leveling)
  4. Ballance ring has dried out or leaked out.
Here is how to check and repair the list above.
#1. Tilt washer backwards so that you can get under the front. Check the large springs and make sure all three are in place on the three points of the triangle base.
#2. Makes sure that this spring is also in place. If so they may be weak and need to be replaced anyway. These are more important than they look.
#3.Set machine back down. Now pull on machine so that the back legs come of the floor. Now set machine back down. Doing this levels the legs on the back.
#4. Open lid and pull tub to one side so you can see the top of both the inside and outside tub. On top of them is a plastic piece that covers the top of both. Shake this and listen for water sloshing. It should have water inside that helps balance machine. If it's dry, you will need to replace.
Please go to www.partselect.com and enter IP4400 in the block where you enter your model number. This will bring up a blow up of every piece of your machine and where you can find them inside the machine. If you click on the diagram that's labeled Machine Base Parts, all the parts I listed other than the ring #4 will be in the diagram. You can see where they go, their part number and you can also order them. I have found that they have the best price on parts most of the time. I sure hope this helps and I'm sure it will solve your problem if I didn't confuse you with my rambling. Good luck and have a great day.
Oct 18, 2009 | Whirlpool Inglis IP4400 Washer
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Washer works fine till it gets to the spin cycle, makes very loud bang bang bang like it's going to blow up, did find two brass pins under the balance plates in a small cup that it droped down into, lined...
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Balancing problem Frigidaire stackable front load washer/dryer
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washer is jumping extremely only when spinning
I own a Malber WD1000, which is several years old. Recently, I had it transported a couple thousand miles across country, and due to the size of the pickup truck it was in, the machine had to lay on its side for the duration of the trip. Shortly afterward, the machine began making a loud banging noise during the spin cycle. Additionally, the door gasket had a "wrinkled" appearance.
After taking various panels off of the machine, I discovered the culprit. The insides of the machine (drum, etc), are more or less suspended inside the outer housing. This is accomplished by means of a pair of shock absorbers on the bottom, and a pair of large springs on top. This allows the inner workings to shake a little bit during the spin cycles, without transferring the vibrations to your floor. In my unit, one of the upper springs had come loose from the frame. The solution involved tipping the machine on its side, with the top cover off, and pulling the end of the spring back through the mounting hole in the frame, then finding a nut and bolt to occupy the additional space in the hole, so that the spring could not slip back out. Getting the end of the suspension spring properly seated again was no small task, but it solved the problem, and now the washer works just great again.
Long story short, I'd check to see if all the springs are in the proper place.
Jan 16, 2008 | Malber P21 Front Load Washer
Banging when spinning,
it is supposed to move freely but ofcourse not bang. what brand is your washer so i can give you a solution to the banging problem
Nov 25, 2007 | Washing Machines
Kenmore 98702 Stacked Washer/Dryer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
