Question about Samsung Digimax A402 Digital Camera
Flashing green light and no flash
Flashing green light and flash stopped working fo no apparent reason.
  • 2 more comments
  • Anonymous Oct 09, 2008
    flash stoppped working for no apparent reason...
  • steveduggan1 Oct 16, 2008
    no flash
  • Anonymous Jan 03, 2009
    yes i have the same problem, can someone tell me how to fix it?
  • lilmixon May 11, 2010
    the flash does not work and the picture comes out dark tell me what to do to fix it
I have the same problem
Posted on Jan 18, 2010
31321321321313131646487987987
Posted on Sep 24, 2008
Sx30is flash off position. I would like to take a picture in low light without a flash. The camera emits a green light as a warning that the flash is off. I would like to not have either the flash or...
The reason the camera has the green light is not to warn that the flash is off. The green light is used to help the camera auto-focus in low light situations. If you disable auto-focus and use manual focus the green light should not flash when taking the picture. Let me know if that helps!
Jul 10, 2011 | Canon PowerShot SX30 IS Digital Camera
Anti lock brake lights flashing simultaneously
I would check the brake pads first to see if they are worn badly, spent a lot time once learning that will cause ABS lights to flash!
Grounding the middle pin on the ABS diagnostic plug , turn on the ignition and mash both brakes to see if the bulb checker light goes out! Very important, left out of procedure on IBMWR, if the red bulb checker light doesn't go out you have a blown tail light or stop light bulb and the ABS won't reset!
Or you have a bad bulb checker module underneath the seat. If the red light goes out then the ABS lights should go to flashing then push the ABS reset button and hold for slow count of 10 or so. Release and try it. Hope this helps!
Apr 07, 2009 | 1992 BMW K 75 S
i loose vga video controller
Nov 16, 2008 | Dell OptiPlex GX260 PC Desktop
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Ice maker not working flashing green
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dfdf
Jul 28, 2008 | GE PSS29NHP Side by Side Refrigerator
Green light flashes
Same thing here....RCA tells me to count the times the light flashes as it apparently is set to "tell" you what the problem is.......3 to 5 flashes means your lamp is messed up.....they are over $300 to replace!
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Green flashes
It is a defective green CRT and most likely the red and blue will need to be replaced as well. This was a known issues with this year of Sony projection TV's.
Apr 07, 2007 | Sony KP-57HW40 57" Rear Projection...
Samsung Digimax A402 Digital Camera Logo
215 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
