Question about Microsoft Xbox 360 Console
Connection problem with xbox 360 wireless adapter.
  • muebe May 11, 2010
    What kind of wireless router are you using? Is it a secure connection? If it is secure did you input the passcode? Did you pick your router or maybe a neighbor"s?
    Problem Solver:
  • 12 Answers
Try to manually input your information for your network. Look under system tab then network and follow the steps.
Posted on Sep 09, 2009
Xbox 360
Best way to use your xbox 360 is with a stable internet connection wired to a router using dsl or fiber connection.
May 14, 2013 | INTELLINET Wireless 300N USB Adapter...
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
How do i configure a wireless adapter for xbox live
To use the Xbox 360 Wireless Networking Adapter with Xbox Live, you must have a high-speed Internet connection (cable or DSL).
Your wireless networking adapter is designed to attach directly to the back of your Xbox 360™ console.
Refer this article http://www.xbox.com/hi-IN/support/xbox360hardware/system_setup/setup_accessories/wirelessnetworkadapter.htm#Attach
Jun 01, 2010 | Microsoft Wireless Network Adapter Xbox...
How to hookup wireless internet
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 07, 2010 | Video Game Consoles & Games
How to conect belkin wireless g usb net adapter to xbox 360
You can not use the Belkin Wireless G USB Adapter for the XBox 360. You must buy a USB Wifi adapter that supports the Xbox 360. (See Microsoft's USB WiFi Network Adapter)
Nov 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
Xbox 360 wireless connection faiures
sure i can help, when you run "test xbox live" where do you fail in the tests?
Nov 06, 2008 | Microsoft Wireless Network Adapter Xbox...
That is because of the radio frequency your wireless devices work on. Go to your router and change your wirless bandwitdth to the highest possible,.
May 24, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox live wireless connection
It only works with the microsoft adapter nothing else. You'll have to buy the Xbox 360 Wireless Network Adapter from microsoft and it cost around $100 bucks. It suxks that microsoft charge for this thing, it should come free with the machine
Oct 03, 2007 | Microsoft Xbox 360 Console
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
134 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
