Question about Frigidaire FGF316 Gas Kitchen Range
Frigidaire gas range model FGF316WGSH, all burners have gas but neither of the igniters will work when the knobs are turned to lite
    Novelist:
  • 112 Answers
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 21, 2010
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Burners will not light
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Feb 12, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Cooktop burner do not ihnite
Hi hgodoy2 - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Nov 24, 2012 | Frigidaire 36 in.GLGC36S9E Gas Cooktop
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
One stovetop ignitor doesn't work: the gas comes out, but no clic
there is a swich behing the knob that turns on the ignition, it most be replace. every burner has one of those swiches, when you remove the knob you can see it, it's white in color about an inch long.
Dec 03, 2008 | Frigidaire FGF378AC Gas Kitchen Range
CONSTANTLY SPARKING
ONCE BURNERS HAVE LITE TURN THE BURNER KNOB BACK THE OPPOSITE WAY A LITTLE BIT AND SEE IF THR IGNITER QUITS SPARKING, HOPE THIS HELPS.
Oct 22, 2008 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire FGF316 Gas Kitchen Range Logo
330 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
