Question about Hammering
I have an Onan 6500 watt genny in my 36 sea ray the generator starts but dies when the start swtich is released i found that if the stop switch is held the enny will continue to run.
  • 24 Answers
Check oil pressure switch
Posted on Sep 18, 2009
I have a onan 6.5 emerald gen,when you start it it quits as soon as you let go of the start button, will run fine while holding start button on,then quits when you release,please help,maybe field not...
More likely the switch is bad, and only make run contact when in the start position.
Easy to test the switch continuity with a ohm meter when it is not running.
May 06, 2011 | Watts Onan Portable Generator - 5000 ,...
Starts easily, run for 5 to 20 minutes and then
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
Jul 26, 2010 | Watts Onan Portable Generator - 5000 ,...
How to fix a genset 6500 generators that stops when you turn starter switch loose?
Check the oil level or any other alarm that can stop it.
The switch may have lost its middle stable position and drop directly to stop.
Try after you have the switch up for starting, let it easy back in middle position. If there it stops again. Try to move the switch down to "Stop". You should hear a click. If not replace the switch with the same type.
Jun 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
Oct 22, 2009 | Watts Onan Portable Generator - 5000 ,...
Lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Jun 05, 2009 | Watts Onan Portable Generator - 5000 ,...
Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Apr 10, 2009 | Watts Onan Portable Generator - 4000 ,...
Hammering Logo
281 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
