Question about Frigidaire Kitchen Ranges
I have a 1996 Frigidaire Gallery Prof. range, the oven is locked
I have a 1996 Frigidaire Gallery Professional Series
I had it on self-clean last night and it still displays ''locked '' on the panel and I cannot open the oven door. What should I do?
Thanks-
Jayme 212-924-4827
  • 1 more comment
  • jaymerich Sep 09, 2009
    Timer is set at zero but lock does not disengage. any other possible solutions? Thanks
    I have a 1996 Frigidaire Gallery Professional Series I had it on self-clean last night and it still displays ''locked '' on the panel and I cannot open the oven door. What should I do? Thanks- Jayme 212-924-4827
    Thank you for your advise, now we feel like we understand what needs to be done. This was very helpful.
  • 6,784 Answers
HI. This will occur when there is a high heat situation that has occurred during the self cleaning cycle(above 915F-930F). This issue will cause the lock relay and door lock wiring harness contacts to become very hot, in return, welding and damaging the lock relay and contacts as well. this will not allow the control to issue the unlock signal, via lock relay.
This high heat issue will be caused by a failed oven temp sensor, which is the culprit. I recommended replacing the oven temp sensor and door lock assembly as well. this will fix your issue.(The control board may be affected as well. check the control board for welded points on the back side)
((It may be possible to reset the situation by unplugging the unit for 5 minutes. This will only work if the damage is not severe(welded contacts on relay). If the reset doesn't produce positive results, follow threw with the recommended repairs stated above))
Posted on Sep 09, 2009
  • 612 Answers
Check you clock timmers. Make sure they are set at zero. If they are not, they will stop you lock from unlocking.
Please rate solution
Posted on Sep 08, 2009
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
I went to clean my oven last night but my oven door wasn't latched. I started the cleaning and the word "door" flashed on the screen. Sure enough my door was not fully latched but the lock mechanism had...
HELLO,
HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    Thanks.
    Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
    Self cleaning lock is in lock position and oven door is open.
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Apr 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How to unlock the frigidaire oven range door and remove error F3?
    How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
    Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
    Self cleaning oven won't lock
    Generally
    There is a motor that lets the latch slide out and catch the door either this latch motor isn't getting power from the board or the motor is bad. You will have to need a volt meter and a wire diagram, and take the covers off to see the motor and board.
    Always remove power until you get the item open and can see whats going on before reapplying power.
    If you don't feel confident I recommend calling in a repair man.
    Mar 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Cannot unlock oven frigidaire electrolux gallery series
    Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
    Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire Gallery Professional Series - No clock/oven functions
    i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
    Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
    How to clean gas oven
    hi,
    use a 2 hour self clean cycle for light soils and a 3 hour cycle for heavier soils. The kitchen area should be well ventilated using an open window, ventilation fan or exhaust hood during the 1st self clean cycle. This will help eliminate the normal odors associated with the 1st self clean cycle.
    when the controls are set, the oven door will lock and the “LOCK” indicator light will flash. DO NOT open the oven door while the light is flashing
    Mar 29, 2008 | Kitchen Ranges
    Frigdaire gallery stove
    lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
    Dec 18, 2007 | Frigidaire Gallery GLEFM397DS Electric...
    Kitchen Ranges Logo
    117 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
