Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
My tv won't turn on it just makes a small electrical sound.
    Problem Solver:
  • 8 Answers
Relay in power supply unit is damaged
Posted on Sep 09, 2009
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
My tv won't stop humming. I have only had the tv for 2 months
make sure you have it and the other electronics plugged into a surge protector strip and all cables wires & connections are fully seated (fully plugged in).The problem is in how the electrical current is being received and it is manifesting the humming sound / " GOD BLESS "
Apr 08, 2013 | Televison & Video
Samsung plasma blinking red light, tv won't turn off
Hello, The real problem is on your TV 'scircuit. Due to high electric power supply there might be a short circuit damage. It's better you call up your service technician and ask him to offer you a onsite support.
Nov 11, 2017 | Samsung PN51D7000 3D Plasma TV
Put vhs in tv, now it won't switch back to tv
see the following step:
1) clean with VHS tape clean the inside componets, rollers, sensor,idler wheel
2) inspect any belt worn or broken.
3)clean with cotton pads, any parts with small amount of alcohol isoprophilic.
4) clean any sensors electric inside very well, and tight connector.normally when some sensor NOT switch back to turn TV.
God bless you
Jul 20, 2012 | RCA 20F610TD TruFlat TV/DVD
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Dark Picture
Your backlight transformer has failed, this is not a simple fix and requires the replacement or one or more of the boards in the back of your tv.
Mar 07, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Sharp CD-BA2100, when I turn it on it starts making a clicking sound and if set to tape one or tape two, it shows "error". When set to "cd" it comes up with error 0306 and the cd tray...
the rubber rope which conect the motor to a small gears to open the cd was cut due to long using ... this sound of clicking coz the small motor is running and its not attached to anything ... its a small rounded rubber rope ..the bad news is you have to break some plastic stuff to reach the motor in the repair depot they change the whole upper part so it costs alot ... but if you can reach it it will work perfect as its new.
Sep 08, 2011 | Sharp CD-BA200 CD Shelf System
MY Samsung LN40A650A LCD TV MAKES A CLICKING NOISE AND WON T COME ON NO PICTURE AND NO SOUND
Clicking sound on LCD TV mostly from incorrect voltage supply for main board, that problem because some part damage or short. Capacitors can make this problem. If you have electricity experience , you can open the rear cover than see if any damage part or blown. For detail Try this.
Good luck.
Apr 08, 2011 | Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Where is the fuse on a Panasonic CT-32HC43. It just won;t turn on. It was working great and then nothing.
The fuse is located on the power supply board. It looks like a small glass tube with metal caps at both ends like the ones in the image below on the board next to it you will see a small marking that says the specifications of the fuse. Ex: 10A(Read 10 Amperes), 120V. The replacement you are gonna purchase should be of the same specifications. Make sure you unplug the tv from the power supply before replacing it so that you will avoid the risk of electric shock.
A positive rating for the advice provided will be highly appreciated and I will be glad to assist you further if you need more help.
Sai.
Mar 29, 2010 | Panasonic CT-36HL43 36" TV
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
