Question about Dell XPS M1730 Laptop Computer PC Notebook
Pa-19 power supply for my Dell m1730 is broken
My power supply for my Dell M1730 suddenly stopped working today. The small blue light on my power supply is going on anymore and it is not sending any power through to my laptop. Unfortunately my laptop ran out of power before I found out what happened. A few days ago it wouldn't turn on but after shaking it a bit it started working again, I tried that again today and it didn't work.
Any help would be greatly appreciated
  • james_thorpe Sep 09, 2009
    it just ran out of charge because the power supply stopped working
  • k24674 May 11, 2010
    What happened to you battery?
  • Dell Master
  • 32,281 Answers
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Posted on Sep 09, 2009
Both fans stopped
Hi
make sure the funs are working in another machine or using a battery if it works the problem is the motherboard.
May 05, 2014 | Dell XPS M1730 Laptop Power AC Adapter /...
Backspace key no working m1730
It is most likely problem with the keypad. contact a good technician.
Dec 01, 2012 | Dell XPS M1730 Laptop
Web cam very low fram rate ( regardless of light levels) xps m1730 dell. no one seems to be able to sort this. I am thinking of buying another external web cam. all the rest in the box is superb. the...
It is a 2007 model laptop. It has a 2 megapixel camera and is expected to be outdated and would not be able to compete with today's webcams. Yes, buying an external camera is the best option for you here. Here is the link of an article in 2007 when the laptop was first released. https://www.engadget.com/2007/08/23/dell-m1730-gets-confirmed-specs-and-release-date
Feb 20, 2018 | Dell XPS M1730 Laptop
The ac power adapter wattage and type cannot be determined . the battery may not charge.
There are at least four possible causes for this error - (error 3600-0749, right?).
First one: the adapter is faulty. You would need a tester to determine whether the adapter is indeed supplying power. Dell will send you a replacement adapter if the warranty is still good, or you can find one online (model PA-19 PN402, 230W).
Second: one of the DC jack solder points on the motherboard cracked. You may see the error disappear by "wiggling" delicately the jack in the notebook. You either need to call Dell tech support and have the MB replaced for free (if under warranty), at cost - in excess of EUR 400 - or the jack may be resoldered, which will void the warranty and requires experience in disassembling and reassembling the laptop.
Third: motherboard is otherwise damaged (voltage regulators, buffers, and so on). Diagnostics must be performed by a Dell technician; replacement policy as above.
Fourth: you may have problems with the BIOS (if it is a brand new unit), solvable by upgrading - Dell will suggest this avenue first if you call tech support, anyway, so check you've got up-to-date BIOS and drivers.
Dec 02, 2009 | Dell XPS M1730 Laptop
Power issues
Dell laptops use proprietary power supply adapters. Inside the adapter there is a communication device telling the laptop the power supply is a genuine dell product. Which in turn allows the battery to charge. Anyways it appears that your charger is having problems. You should probably try to locate one local (from friend or computer repair shop) to test. if you try a good one with no problems, then just get on Ebay and get you a genuine dell charger. they are about 40-60 dollars. Or try calling dell.
If trying a known good charger doesn't correct the issue, you could have broken solder pins on the power jack inside the laptop.
If this helps you solve you issue please rate my solution.
May 05, 2009 | Dell XPS M1730 Laptop
Dell XPS M1730 Laptop Computer   PC Notebook Logo
603 people viewed this question
Alun Cox
