Question about GE Monogram ZIR36NMRH Refrigerator
Temperature on both freezer and refrigerator running at 2 and 41 what should I check I lower the temp and it goes back up
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
How do we raise the temperature in our fridge and freezer?
Well, you didn't leave a model number, so I'll just give you the generic answer: If you keep pressing the Frz or Ref temp buttons, the temperature will cycle down to the lower limit and then pop back up to the upper limit and then repeat all over again. If not, look for up/down buttons, or +/- buttons.
Oct 21, 2014 | Refrigerators
Da99 samsung fridge freezer
As for freezer, lower the letter and allow 24 hours for temp to adjust. Lower again and wait, until desired temp achieved.
Do the same thing for refrigerator. If freezing not working most efficiently, this can and usually does affect the refrigerator.
Go to http://www.buzzle.com/articles/refrigerator-temperature-settings.html for more info.
Mar 02, 2014 | Refrigerators
Just bought a Dometic DM2862 fridge. Freezer on goes down to 12 deg. and lower unit down to 38 deg., but during day the temps are: freezer - 22 deg. and lower - 44 deg. Is this normal? Can I fix this?
While there is some fluctuations in temperature in Dometics from night and day, but it is usally the reverse of what you state. Warmer in the day time when the unit is opened more. I would check the temperature settings and if they are correct then check the thermostat.
Aug 31, 2011 | Dometic RM2652 Refrigerator
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Tempurature Goes Up
sounds to me like your thermostat is bad
Jul 10, 2009 | GE Q Series GSS25QGT Side by Side...
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer always about same temp as the upper refrig section
Check those coils underneith. They are making the machine work harder IF they are dirty. They may be full of lint and cobwebs. All that needs to be removed.
Mar 31, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Whirlpool refrigerator does not turn off
Lowering the temps will make it run longer.  You don't give any other data so it is hard to know what the issue is...try defrosting the unit completely to get rid of ice which may not allow the unit to work properly.  Freezer should be at about 0 F and fridge at 40.  Use an outdoor thermometer to check this.  Leave door closed at least an hour before retrieving the thermometer.
Nov 20, 2008 | Refrigerators
Refrigerator and freezer temperature control
hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Sep 24, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
GE Monogram ZIR36NMRH Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
