Question about Frigidaire GLTR1670A Front Load Washer
The clothes are very wet not being wrung out - Frigidaire GLTR1670A Front Load Washer
    Problem Solver:
  • 13 Answers
The washing machine is not going through the "spin" cycle.
Posted on Sep 08, 2009
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Hooverlightflashing
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Nov 25, 2013 | Dryers
Paper wont feed from the tray gets jammed every time
Take note:
Usually in the tray paper jams are caused by the pick-up rollers being dirty so clean them using a well wrung wet clothe.
Also the clutch and soleinoid problem. Also take not of the transport system for the paper if there is anything not in its right position any thing loose they must have somewhere you shold afix them.
Jul 18, 2011 | Brother IntelliFax-2820 Laser Fax
Sharp F02950m not pulling paper
Does it give you a sound that it wants to pull a paper if so then the rubber like responsible for pulling the paper is dirty and needs to be cleaned with a properly wrung wet clothe.
if it does not give you a sound that it want to pull the paper then the problem is with the clutch or the solenoid in the pick-up system. one or both need to be replaced
Jul 14, 2011 | Sharp FO 2950M Plain Paper Laser Fax
My GE washing machine does not spin the water completely out of clothes. Garments come out very soggy and have to be wrung out by hand before putting them in the dryer. Any ideas?
My washer was pausing during the rinse cycle, sometimes leaving the clothes very wet as well. I pulled out the filter underneath the lower panel, it was packed with coins, etc. Has been running fine (draining) ever since. Hope this helps...
Oct 01, 2009 | GE WSXH208A Front Load Washer
Clothes very wet after end of cycle
sounds as if you have ablockage within your pump assy, remove the lower acess panel and undo the "button trap" your problaby clogged up with debris
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clean glue off the screen of the LG VU
try using a little white spirit to loosen the glue then use a soft cotton cloth with a little soap to remove the residue and wipe clean with a warm soft wet (wrung out), cotton cloth followed by a dry soft cotton cloth.
Turn the phone off first before cleaning.
Nov 17, 2008 | LG Vu CU920 Cellular Phone
SCANNING
Clean the glass surface with Isopropyl Alcohol (IPA). Dont use any other solvent. You can also use a well wrung wet cloth to clean the glass.
S. Mohan
Jul 23, 2008 | Umax Astra 2200 Flatbed Scanner
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Frigidaire GLTR1670A Front Load Washer Logo
160 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
