Question about Philips Magnavox 27MS343S 27" TV
My TV shutting itself down
My TV is a Magnavox and it keep disconnecting and shutting down in a second-period. It turned me crazy, i dont know why it's working like this.
Can you advice,
  • 3 more comments
  • Anonymous Dec 10, 2007
    My Philips TV keeps shutting down after you turn it on . After it's off, the sensor light keeps blinling. Model 27PT5441/37
  • iff2in Dec 12, 2007
    Hi we have same problem. It was just working fine and all of a sudden, its started showing some lines (horizontal) for a while and all of a sudden, after 2 -3 weeks, started sutting off, after couple of minutes.
    Can you suggest any solution to resolve this problem
  • Briarose Jan 02, 2008
    We have the same problem, with tv shutting down, and going into standby mode, after a few minutes. Have had it since 2002, and it is a philips, model no. 29PT6361.
  • Anonymous Jan 02, 2008
    TV shutting it self off
    MEHMET Mar 11, 2018
    Sharp smart tv shut down by itself after 5 minutes if it rest a long time. Then shut down after some seconds.
    Tv used to shut down by itself after 30min when I bought it as used and i opened big holes on tv cover on behind. then the time delayed up to 3 hours.
    But now it shut down after 2 seconds if tv rest 10 hours the time is initially 5 min then 1-5 seconds.
    I changed 7 pieces capacitors but nothing changed. The power card number is HLL-4255WJ
    And it has 12v and 16v output, 12v is always constant. On 16v output, there is 19v when tv standby, when the tv is working it drop to 17volt.
    What is the problem?
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Posted on Feb 12, 2008
Magnavox television won't stay on
I know this is going to sound strange but I have something to check. If you have LED lights in your house turn them all off. When they are off turn on your TV and see if your TV stays on. Yes, there could be many problems but this one is cropping up quite a bit. If this does not work then you need to take a look at the power supply board.
Feb 15, 2015 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox # 37MF231D
that depends on the value of the television and the cost of replacing the power supply and connections.
Most likely you have a short in your power supply or other connections causing the tv to protect itself by shutting down. You can check with our Repair Service lookup icon for a repair service near you.
Before you call them you may try unplugging your unit for 30 minutes or so and plugging it back in.
Jun 26, 2008 | Philips Magnavox 27MS343S 27" TV
Shut down
Sorry, I do not know that set.
Feb 24, 2008 | Philips Magnavox 20MS3442 20" TV
36 magnavox tv shuts off by itself
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Flashing green light
Hi I have the same problem with my tv.. how do i fix this?
Dec 31, 2007 | Toshiba Televison & Video
My TV keeps shutting off
Tvtek is on the right track. The remote will not solve the problem. Sounds like a voltage regulator in HV circuit if it only lasts a few seconds. If it stays on for a couple of minutes, beam limiter cicuit is pushing to overload and shutting unit down. Magnavox set not hard to repair, but a 27" set is not cost effective to repair either.
Jun 06, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
371 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
