Question about Sony Cyber-Shot DSC-W220/B Digital Camera
Water Damage to View Finder
My Nikon S51 was in the bottom of my backpack with a damp towel sitting on top of it for a day or two. Now when I turn it on the view finder is multi-colored and partially black. It appears that the camera is working okay, only I cannot see the picture that I am taking...any suggestions would be greatly appreciated!!!!
  • Sony Master
  • 7,993 Answers
Try cleaning the viewfinder with a damp (again?) soft cloth. You can use a product recommended for cleaning camera lenses. You can still use the screen to view the scene you want to shoot. (I am assuming that what you call the viewfinder is the small eye that used to equip all cameras, before it was replaced by the view screen.)
Hope it helps.
Posted on Sep 09, 2009
My son put water on my laptop , I wait for one day to remove all water, and after my laptop doesn't turn on.
Unplug the laptop.
Put a good, clean towel on a flat surface, like a table.
Turn the laptop upside down, so the keys are facing the towel.
Let it sit for a few days and drain.
Do not turn it on during this time, as you may short out portions of the system, if that has not already happened.
After about 5 days, turn the laptop face up and take it off the towel.
Replace the towel with a new, dry one, and turn the laptop over, and gently shake it over the new towel.
Feel the towel, everywhere the keyboard may have shaken out water, and see if there is a damp spot anywhere. If so, then it is still not dry.
If it is not dry, repeat the first few steps with another dry, clean towel, turn the laptop upside down, and let it sit another few days.
Do this until you are certain there is no more moisture.
Since you indicated that your keyboard was full of water, this might take a long time, but it is better to be patient and do it this way, than to turn it on too soon, and short out the components, located under the kayboard. Basically, everything important is under there, like the motherboard, the hard drive, memory and other control components.
Good luck. Try to let us know how it goes.
-a.
Jul 13, 2012 | Computers & Internet
Prints a line top and left
You may have to do a clean and wick on the cartridges. Please Follow the Below Steps:
Take 2 Paper Towels one should be Damped with Luke Warm Water and the other one should be Dry.
Take the Cartridges out of the Printer and on the bottom of the cartridges where you have the ink coming out of place the Damped Paper Towel on It and Remove it, Do the Same Procedure thrice.
Once thats done, Place the Dry Paper Towel in the same mentioned way. Try to Print.
Good Luck!!!!!!!
Feb 15, 2012 | Epson Stylus Photo R300 InkJet Printer
Is it worth buying a new print head for i560 printer (Canon)?
Why do you think the head is bad? Treated with care, these things are bulletproof.
I have an i560 which was discarded but clean. I first ran a test page and the printer worked fine, but with many streaks.
Part of that was "fuzz" stuck under the head wiping across the paper. The other part was clogged jets. Here's the cool part.
This head is built like a tank and is very easy to remove and unclog.
First always remember, NEVER place the head jets down on anything or touch them with anything other than LIGHT pressure with a soft paper towel or cloth.
Remove all 4 ink tanks and if they have a decent amount of ink in them, and are not very old, carefully place them upside down somewhere safe, label side down, ink pads up. Work quickly to minimize ink evaporation this point forward.
Remove the head assy. lifting the blue latch on the right side. It's pretty spring loaded. This will completely release the printhead.
Carefully pull the top part forward, then up and out. Don't touch the gold contacts but do check visually to see if they're clean. If not, a soft damp cloth will likely clean it up and get old ink off.
Use a small plate with about 1/2" of warm water and holding the printhead by the edges, place the jets just into the warm water. The water will instantly start to turn brown from all the ink. Using a dry soft paper towel or cloth, take the head and gently press the towel onto the metallic jet assemblies and draw out all the old ink. You will see black from the K jets, and tri-colors from the CMY jets.
You can repeat this with clean warm water again. Remember not to take a long time as your ink tanks are sitting open. 10 minutes should be more than enough time.
Use wet qtips to clean old ink from around the inside of the head, where the tanks go, around the outside of the round silver screens. There are rubber seals there and you want those clean. The screens are very delicate and do not touch them with anything.
Use dry qtips to remove all water from the seals and any other area in the head assy. Again, do not tough the screens.
Finish by using a damp towel to very gently wipe down the bottom side and the ink jets. A little more ink will probably come out into the towel.
Once everything a dry, place the head carefully back into the printer locating the bottom, jet part first into the carriage then push the top part with the contacts toward the back to seat it. make sure it's all the way in by slightly "jiggling it". It should not move around and be "in".
Move the blue latch to the down position to lock in the head.
Replace the ink tanks but make sure ink is not leaking out the bottoms as this indicates a bad seal on the tank and it's a gonner.
Close the printer cover and let it complete the automatic cleaning cycle.
Print a test page:
With the printer on and idle, press the right paper eject/cancel button and hold it down until the green light flashes off-on TWICE then remove your finger. It goes like this "hold down button, green light goes off, flashes on-off...on-off... release button!
This triggers a 4 color test print and will show all the black jets and color strips for the color jets.
If everything is clean (and it's going to be a LOT cleaner now!), you should see nice even colors and a nice stairstep pattern at the top for the black with no missing lines.
If it's pretty good, but has some minor issues, you're close.
You can open the printer and repeat the warm water procedure.
One other thing I did you really clean out all the old ink was to use an eye dropper and place a drop of the clean water on top of the metal silver screens. Then gently press a towel up on the ink jets as before. You will see the water sitting on the screens disappear as it's drawn into the jets and you will see even more ink coming out.
This should give you a brand new printhead.
If you see any debris or ink or discoloration on the gold contacts (they should all be shiny gold), you can gently use a damp CLEAN towel to gingerly wipe off the debris.
As a last resort, if some look discolored, and SOFT PLASTIC eraser (like Mars Plastic) can be used to clean them using minimal pressure. Any eraser dust must then be brushed off with a soft brush, or a damp CLEAN towel followed by gentle wiping them dry.
In my case a poorly operating head to this day (years later) prints totally perfectly as if new.
Despite what DocPlayer claims, these heads are solid, meant to last (as opposed to the throw-away ones) and are durable.
The most vulnerable part are the ink jets themselves with are highly precise and tiny and easily damaged through carelessness.
Treat them gently and with nothing other than soft paper towels or cloth so they cannot get scratched, and assuming there is not any damage to them, you should have a brand new head.
I have resurrected these heads myself and every time, they cleaned up and run perfectly.
Finding new replacements, I suspect, would be difficult and likely not worth the cost. So there's noting to really lose cleaning it up if it's not working well. The odds are on your side it will work great.
HP printers can be as cranky as AnY inkjet. Even the i560 hates to sit unused. All inkjets need regular use to keep them happy. I don't care who makes it. They all rely on liquid ink which when sitting long enough, starts to dry. Simple physics.
Printing a test page (two blinks) is easy, doesn't need a computer even connected, and excersies the printing plumbing. I try to do it at least every two weeks or so and everytime I have a print job I need to do and the printer has been idle for a few days.
One more thing. Try not to unplug the printer and always keep it powered when it's turned off. There are internal timers which keep track of idle time and perform different types of head cleaning automatically.
If the printer loses power, it loses the timers and you will then force it into doing a full cleaning cycle which consumes a significant amount of ink when it's not necessary.
Also avoid opening the cover often and for long times as this also gets timed by the printer and will cause a cleaning cycle due to the fact it has left the inkjets exposed to the air.
When parked, the jets are sealed by rubber covers when not in use keeping them moist.
Good luck.
Oct 04, 2010 | Canon BubbleJet i560 InkJet Printer
I havve a nikon S51 the battery latch is broken
they can repair/replace according to the damage and how it broke off. if the door broke into pieces it will be replaced. Replacing is done 99% of the times since it offers the pressure the battery needs to continue to charge well.
here is a discount code if order is placed today june 3rd, MD2010 - promo link: www.teleplancamerarepair.com/md2010.asp
non promo link; www.teleplancamerarepair.com
Jun 01, 2010 | Nikon Coolpix S51c Digital Camera
MINE CANNOT START,WILL A DAMP TOWEL KILLED IT BECAUSE I LEFT IT ON A TOWEL WHEN I WENT TO WORK
If the notebook was running when it was left on the damp towel it is possible that the fans sucked in enough moisture to damage some components by shorting them out. The heat from the computer would have intensified the available amount of moisture from the towel. If the laptop was off and the towel was just damp and not soaking wet it is most likely that the case protected it and no water damage was done to the internal components.
Jan 07, 2010 | ASUS Eee PC 1000H Laptop
Won't print black
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 19, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Images displaced, cut off at bottom & extra content at top
Be aware of using your Flash because it has limit syncronization capability. if your flash synchronization limited only to 250 speed, and you make it 500, the images may turn half lighted and dark.
X synchronization is important to know.
Jan 10, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Images displaced, cut off at bottom & extra content at top.
flash trans. is broken i want to replace if there any matching ?
Dec 01, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Praktica sport zoom 7-21x25
I have the same problem with my Nikon N65 film SLR and I bought a vintage Super 8 movie camera where the rubber had turned to the consistency of gum on a side-walk on a hot summer day. On the a camera I carefully rubbed on a coat of talcum (which probably isn't the best thing to use on a camera but I was careful and it isn't something I do every day). I then took a small square I cut from an old terry towel and used friction and elbow grease to rub off the top layer of the rubber. I then took another square of the towel and dipped it in hot soapy water, squeezed out the excess and washed all that remained. I then took a small water-colour brushed (after I dried the surface of course), and dusted the surface of the rubber with talcum and let it sit overnight. This seemed to stop the derioration and clear off what had built up. The next day I took a very dry damp towell (if that makes sense) and wiped off the surface. It pretty much took care of that problem. That was the Nikon, it was only in the beginning stages, the Super 8 camera which had apparently hadn't been out of the case in 20 years. The Super 8 was so bad that I don't even know what had deteriorated, probably a rubber eye piece, that one was time consuming but basically I put the powder on carefully and just wiped big clumps off the metal eye piece. The powder just served to make it easy to clean up and kept it from turning into a 3 stooges farce with one thing sticking to the other and so on. Well, I hope this helps, I don't know why it works, maybe there's a chemist out there that can explain it to me. Good luck!!
Jun 29, 2008 | Praktica Roof Binocular
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
Jun 26, 2007 | Nikon Coolpix 5700 Digital Camera
Sony Cyber-Shot DSC-W220/B Digital Camera Logo
97 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
