Question about SVA-USA VR 17S 17" Flat Panel LCD Monitor
I have a sva VR-17S monitor and i am trying to use this for my other computer and i need to download the software. where can I find it ?
  • 32,281 Answers
Normally you don't need a driver for a monitor, any screen resolution adjustments is done by the Control Panel - Display - Settings.
Posted on Sep 09, 2009
USER Manual For Need a SVA VR-17B LCD Monitor
Did you try their web site? http://www.sva-usa.com/
This is 2005 model so it will be real hard or impossible to get.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 25, 2011 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
SVA VR-17s, I inadvertantly reversed the 12v power. I plugged it in and heard a snap! That was all she wrote. Can I replace a diode or other component?
It difficult to say what thing or things got damaged when they are reversed biased. If you are lucky it could just be a fuse, otherwise there could be a lot of components that could be damaged by the reversal. Only way to know the extend of the damage is to pop open the case and look inside. I would check if it has a fuse first and the condition of it and look for any obvious parts that were blown up. Unless you know how to troubleshoot electronics, it not worth the trouble to try to see if you can fix it considering how affordable LCD monitors have gotten.
Apr 21, 2011 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
My screen is green I cant find the menu key on my sva monitor
You need to find menu button - it's got to be there somewhere. If you do find it, go to the "tools" menu (show a wrench and screwdriver), then select the "RECALL" option. Press then right and/or left arrow on that option. This fixed same problem on my SVA Monitor
Good Luck
Nov 19, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Sva monitor flickers when I turn it on.
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Mar 12, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Where can I download a user manual for my SVA 75S? I can't figure out how/what to use to connect to my tower so that my speakers in the monitor work. Thanks
Hi
You may have noticed two or one stereo jack like. It is similar to a headset jack.
Normally it is green in colour. If not it is black or it has a sign like the image below .
Plug it into your sound card the green channel into your cpu.
Jan 13, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
No display under 1024x768
I have the same problem with 800x600. I've found that by setting the refresh rate to 56 Hz, I can get the games to play. For instance Age-Of-Empires II only works with this method. My old monitor worked fine, and this works at 1280x1024.
Apr 22, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
My sva monitor shakes can you help
See solution for "display shivers due to magnatic field"
Apr 09, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Cant find anywhere to download my driver
they may be no drivers for it, windows install is like a plug and play monitor
good luck to you
Oct 25, 2008 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
297 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
