Question about Grohe 24'' Relexa Shower Bar with Swivel Hand Shower Holder - 28666/Choose
My handle moves from right to left, right side being cold, left side is hot. it gets hot no problem but then if i put it in the middle which should be warm or cooler sometimes it loses its pressure until i turn back on hot. someone told me it could be a cartridge problem
  • 8,197 Answers
You have a bad cartridge. You need to replace it to work right again. there is a small block in it some where.
Posted on Sep 10, 2009
I have a moen posi-temp shower valve and it says "up" on 1 side. when it is installed this way the hot is on the wrong side. the hot is hooked to the left side but the handle points to the cold...
you need to pull apart the handle and rotate the cartridge 180 and reassemble and that will put the hot on the left and the cold on the right before you put the screws all back in test it to make sure its correct then reassemble IF THIS HELPED YOU PLEASE VOTE FOR ME AND LEAVE GOOD FEEDBACK
Aug 27, 2011 | Moen & Posi-Temp Single Handle Shower Or...
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Hi, we have recently purchaed a new triton alicante shower only to find that it constantly alternates from hot to cold. the alteration is too frequent to be enjoy a shower since it wll go hot then 20odd...
try taking the handle off and moving just the stem till the right side has all cold and left side is all hot..this mite adjust the stem
Nov 22, 2010 | Home
I have a single handle Moen kitchenfaucet. I
You turned the faucet body when you tightened faucet you need to loosen and reposition body so handle goes left and right equally and retighten while making sure faucet body does not move
Nov 12, 2009 | Moen Plumbing
How do you adjust the hot and cold on the shower. it wasn't working so my husband took out the screws on either side of the face plate, now hot and cold reversed
The cartridge just needs to be turned 180 degrees to put hot and cold on respective sides. As far adjusting temp., right behinde handle there should be two pieces bigger one goes in first. The smaller of the two is more ring like with a sqare on top, the more the sqare is rotated to the left, the more the handle can turn to the hot side of valve. I hope that makes sense.
Oct 03, 2009 | Moen & One Handle Tub & Shower Faucet
99 Venture, Passenger side gets cold, drivers side stays hot
SOUNDS LIKE THE VENTS ARE PULLING AIR FROM OUTSIDE, YOU CONTROLS FOR THE VENTS ARE OFF SINQ. TRY TO MOVE THE CONTROL BACK AND FORTH WORK THEM HOT TO COLD AND DEFOAST TO HEAT TO AIR WORK ALL THOSE EVERY WAY YOU CAN ,MIGHT HAVE A STICKING VENT OR VALUE, THANKS HOPE THIS HELPS ,ROBERT
Jun 16, 2009 | 1999 Chevrolet Venture
Water is either hot or cold
yes, the valve should be close at the downward postion. and the water should be clod to hot from left to right.
open the handle and pull out the cartridge.
make sure the valve body is installed right side up.
if it is, insert the cartridge with the lock pin on top.
reinstall the handle.
Jan 27, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Lavortory one handle faucet will not move to hot side
go to a plumbing supply store and obtain an american standard kit to rebuild the faucet. good luck
Jan 18, 2009 | Plumbing
Grohe 24'' Relexa Shower Bar with Swivel Hand Shower Holder - 28666/Choose Logo
118 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
