I have an problem with my lg tv the 3 red white and yellow wires from the playstation that connects to the front of the tv where the wires goes, well when i plug the yellow video wire in it goes to f s-video ans should go to comport, how do i fix this problem
  • 10,594 Answers
S-Video jack has inbuilt switch that seems stuck inside. Plug/ replug S-Video cable jack in S-video input (at front of TV) that might correct that stuck switch so TV will sense yellow video input instead of S-video.
Thanks.
Posted on Sep 09, 2009
How do you connect a ps3 to a Emerson 32" TV, with yellow, white, and red cords
your yellow is the video in, white audio left, red audio right.
Feb 25, 2018 | Emerson Televison & Video
I have a polaroid hdtv 32gsr3000 and trying to hook up a sanyo dvd to and when we play a dvd it has no coler all black and white we are using 3 cables that came with the dvd player.
Make sure you connected wires right both on player and tv. There are Two ways to connect it.
1. Use 3 wires: white, red, yellow. White and red are for audio and yellow is for video. Yellow need to be connect to yellow port on TV and DVD player
2. 5 wires. Again red and white are for audio. And there is another red plus green and blue. Those 3 are for video and have to be connected to corresponding ports on TV and pkayer. Make sure you don't mix up red wires
Dec 03, 2017 | Polaroid Televison & Video
My lg telly has no sound or picture power button just flashing red
There are red,white,and yellow wires at the back of the T.V. Make sure
that the yellow wire is plugged into the yellow plug in hole, white wire has to be plugged into the white plug in hole, and the red wire plugged into the red plug in hole.Sometimes for the red wire you have to plug it in a black plug in hole. Make sure your T.V. is connected to you reciever. If this doesn't help I'd try calling somone to fix it for me.
Jun 24, 2012 | LG 42LC2D 42 in. LCD HDTV
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Good evening, My son has been using his Playstation 3 on a TV with a resolution of 1080p. Now he is trying to use the console on a lower resolution TV. Can you tell me how he can reset his console so he...
OK if hes connecting it to a TV with a red/white/yellow cable then you need to connect it to the 1080p TV again with the hdmi cable but with the red/white/yellow cable on the same tv at the same time. Then in display settings switch it to the red/white/yellow cable setting and thats it. It should be good for the red/white/yellow cable TVs.
If its a TV with hdmi but more like 720p then just use the 1080p tv and go to settings then switch to 720p and there.
Sorry if this is confusing.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Im trying to connect my playstation 3 to my 42 inch LG lcd tv
When connecting the ps3 to a nice TV like that, you want to use an HDMI cable. You can use the stock red white and yellow plugs to connect to the back of the TV, however you will not get the full HD experience like with the HDMI cable.
Dec 25, 2010 | LG Televison & Video
Canrt seem to get a connection from box to the tv.all wires are in correct .have tried the hold the button untill it beeps twice an still no picture. platstation 3 3-275772-01
  1. Make sure the AV Cable is connected to the AV MULTI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the AV Cable into the yellow port for video, and into the white and red audio ports on the back of your TV.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive ON/OFF button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the Standard Resolution (or detect the current display output settings of your TV/monitor).
Jun 25, 2010 | Sony Video Game Consoles & Games
How do i connect the playstation 3 to tv, it was connected to hd tv then we have tryed to connect to normal tv and nothing. please help
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
Jan 08, 2010 | Sony PlayStation 3 40GB System
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
