Question about Xerox WorkCentre M-24 Color Copier
Xerox M24 Transfer Belt Torn
I have a torn Transfer belt on my Xerox WorkCentere M24
Can someone tell me where i can buy a new transfer belt for a xerox WorkCentre M-24? Xerox isn't helping me on the situation of finding parts and they also wont help me because i don't have a maintenance agreement with them. another question do i have to replace the whole transfer belt unit or can i buy just the transfer belt and replace the torn belt?
  • Anonymous Mar 28, 2014
    how do i remove the belt
    President:
  • 3,085 Answers
Where is the transferr belt cleaner on a xerox workcentre m24
On the right side in the center of machine there is a small door you have to open that door and there will be the transfer belt there is also a handle to take it out you have to grab that handle and take it out slowly you will see the cleaning blade and assembly on the left side
Jan 23, 2013 | Xerox Workcentre M24 Color Copier
Need to replace transfer belt cleaner and 2nd bias transfer roll
Both are probably still good but the HFSI (High Frequency Service Item) counter needs to be reset. Unless something has changed with them that has to be done with the service laptop hooked to machine with a serial cable and using M24 diagnostics.
Jun 20, 2012 | Xerox WorkCentre M-24 Color Copier
Hie,am looking for a xerox M24 transfer belt at a cheaper price.Can you please help.Peter
One of the best prices I have seen and they have the best aftermarket support for Xerox.
http://www.partsdrop.com/belt-64k91451-xerox-style-dc3535-p-1782.html
Good Luck with your Xerox and Thank You for using Fixya.
Jan 11, 2011 | Xerox WorkCentre M-24 Color Copier
How to replace the cleaning product of belt transfer (m24)? Thank you for your answer
1. Remove IBT Belt Assembly (REP 9.15).
2. Remove IBT Cleaner Assembly (REP 9.16).
3. Remove Stand Plate (Figure 1).
a. Remove screw (2).
b. Remove Stand Plate in direction of arrow. Stand Plate will be installed in new location
in step 7.
Jun 26, 2010 | Xerox WorkCentre M-24 Color Copier
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Error code sc481 for ricoh copier 1232c
This is a "Transfer belt mark detection error" This means the transfer-belt in the PCU is torn or separated where it has a mark that flags a sensor telling the machine where the belt position is, The fix is to replace the entire PCU. 4 Screws that have arrows pointing to them surround the unit facing you when you open the front door will release the unit allowing you to insert a new unit and the code should go away ,, good luck!
Apr 30, 2009 | Ricoh Aficio CL3500N Laser Printer
Torn transfer belt
quite straight forward, but obviously tricky the first time. Basically take off all the brackets on the top and on the outboard end of the belt assembly there is 2 more brackets screwed onto the side. Remove these (5 screws in total i think) and then release the tension roll (the one that pushes up on the left hand end if uyou have just took the right brackets off. The tension roll can be held in a non tension position while the belt is removed/replaced. Let me know how you get on or for further help
Mar 13, 2009 | Xerox DocuColor 3535 Copier
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Xerox WorkCentre M-24 Color Copier Logo
816 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
