Hi - Received a LG monitor, W53 Series as a gift.
Hi - Received a LG monitor, W53 Series as a gift. trying to set it up to use with a laptop. Can not get the screen to display more than "analog power saving mode"
    President:
  • 2,022 Answers
In your laptop there is button press f5 or f6 to get dipaly on lg monitor or you can right click and go to display properties and set the dispaly.
Posted on Sep 09, 2009
How do I unlock screen controls for LG W53 27" monitor?
Press and hold the Menu button for several seconds to toggle the OSD (on-screen display) Lock on and off. The Menu button is the third button from the left in the group as you look at the front of the monitor. You should see a message on the screen when the OSD lock is disabled.
The OSD Lock feature is described in the manual and is the same for all W53 monitors. See http://www.lg.com/us/support-product/lg-W2753VC-PF for the manual of one of the monitors. The direct link to the manual came up as http://www.lg.com/us/lgecs.downloadFile.ldwf?DOC_ID=KROWM000230850&what=MANUAL&fromSystem=LG.COM&fileId=KROWM000230850.pdf&ORIGINAL_NAME_b1_a1=W2753VC_EN.pdf .
I hope this helps.
Apr 12, 2016 | LG Computers & Internet
My lg w53 won"t fire
it might just be confused....interrupt the power to it via the breaker or by unplugging it for a few minutes.....
Mar 08, 2011 | Computers & Internet
HI I have used LG Flatron L1915S computer monitor. When I plug it into my laptop, it blinks showing the laptop desktop for less than a second then goes black. Other monitors works fine when I plug them...
There is often a function monitor key on the laptop, located near the F7 key area, the icon looks like a monitor on|off and is typically in blue. this key is to be used in combination with the Fn key to enable, disable the external monitor or enable both monitors or just the laptop. Press the key combination until your laptop panel lights up while the monitor is plugged in. Now check your extenal monitor refresh rate and resolution slider settings by right clicking on your desktop go to properties / video settings. (please note monitor settings are under advanced). You should see two monitors in there now. use "identify" button so you know which one to work with. on the external monitor settings, decrease (slide left the slider all the way). If you can set the monitor refresh to 60Htz. Lastly take a flashlight and check if you can see a shadow of your screen on the external monitor, if you can that means the backlight is not working and likely needs the inverter replaced. Hope that helps ! Cheers
Aug 30, 2010 | LG L1915S 19" LCD Monitor
My LG W53 stopped working
check all the wires that they are properly attached
Jun 02, 2010 | Computers & Internet
How do you unlock the LG W53 Series LCD Monitor?
Hold the menu button down till it says "OSD UNLOCKED"
Jan 09, 2010 | LG Computers & Internet
Black screen/flickering
try using an external monitor, if the problem doesn't happen on the external monitor then definitely the problem is with the LCD screen. Possible replacement required for the LCD panel.
Jul 13, 2009 | Compaq Presario CQ50-215NR Notebook
Can´t connect my laptop to tv monitor
Try lowering your screen resolution on the laptop first. (Right click on desktop > properties > settings tab > and move the bar to the left - try the lowest setting to start with
Jan 22, 2009 | Acer Aspire 4720 Notebook
Monitor configuration
Did you also install the LG software and LG Drivers correctly?
With my LG flatron i received a piece of software to optimize my settings and even calibrate the monitor. I run win XP ME.
Jul 04, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
Unlock N75
all pin codes for nokia N-series is 12345 try to restore on factory settings
May 17, 2008 | Nokia N70 Cellular Phone
No sound coming through tv speakers
Hi.
Some Large flat panel tv sets have seperate speakers that clip on to the side of tv set if you got the manual with the tv does it say about seperate speakers.
Or if it does have speakers with the tv set check that the audio frequency is set to your countries transmission frequency.
Example UK is PAL (I) If your not in uk try and find out what yours is.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Televison & Video
Computers & Internet Logo
402 people viewed this question
David Payne
David Payne
