Question about Garden
I have a Partner K700 Active II block saw that loses rpm's after cutting 2 blocks. I can't get the RPM's up until the saw is totally cooled down. Does anyony have any ideas what might be causing it?
The problem with any 2 stroke engine, if left for a period of time without being run and gas left in tank will cause the diaphram to dry up thus causing poor atomization in turn will cause low RPM and very hard to set.
Every time one uses such tools, and know that it will be left for a period of time without being use. One should empty any gas left in tank, then stat the motor and let it turn until all gas in caburator has been used.
I'm pretty sure this is the cause of your problems, had it happen to me before.
Easy fix is to get a new diaphram install in caburator. This should solve your problem.
Posted on Apr 22, 2010
    Brigadier General:
  • 4,088 Answers
Check the muffler for plugging. Clean or replace the air cleaner. Check the spark plug condition. Preset both H and L jet screws 1-1/2 turns back from CW stops. The saw will run with these basic settings. Warm the engine up and pull the throttle full on. Adjust H for high speed, but 4-stroking. It should smooth out immediately when cutting. Release the throttle and adjust L for smooth idle, but rich enough to allow the engine to follow the throttle. Adjust idle speed screw so that the chain just stops turning. Make sure the chain is being oiled and not too tight.
Posted on Sep 12, 2009
Partner Saw K700 Active 2 new carburetor won't start
Is there spark? May not be a fuel problem
Jul 28, 2016 | Garden
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
I have a Partner K700 Active ii cut-off saw that has run very well up until this week. Starting the saw now it will not pull at all. Wheel seems to be jammed because the pull cord and pulley system all...
Pull plug out and use flash lite to inspect. Retry startingwit plug out ,u can pour some marvel mystery oil in the plug hole not a lot but enough toget it unstuck let me no what happen please
Jul 22, 2014 | Garden
Engine loses rpm
What is the year make and model?
Feb 19, 2014 | John Deere Kawasaki K Series Air Cooled...
Looking for year made, of a partner cutoff saw k-700,serial number..3440420need it to order parts
The K700 active and active 11 had a t bar on the side of the blade guard which you pull up to adjust it, and the cutting arm and belt guard are held with 13mm nuts, the active 111 had a plastic bracket on the top of the blade guard which you push to move the guard, and the belt guard and arm are held on with 13mm bolts.
Jan 13, 2013 | Husqvarna Partner K650, K700, K750, K950,...
My air condition blocks some ice in the system, causing not enough cool provide.
Water leak /Icing in your evaporator is the common problem in split airconditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4.Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replacemotor capacitor.
Dec 18, 2010 | Heating & Cooling
Need a part for a k 1200 mark II Need to know where nearest dealer is for zip code 45631
You can use the Dealer locator on the Stihl USA website. It will direct you to the dealer that is closest to your zipcode. I have posted the link HERE.
Oct 18, 2010 | Stihl Cutquik Saw Partner K650 K700...
Disco 2, 2002 model. Sudden lose of power and rpm not exceeding 3000. If idle the rpm goes to 3500. secondly, the rear suspension keeps on falling down after more than 5 minutes packing. What could be the...
Could well be a fueling issue, best to change the filters and try it again. If it's a TD5, the throttle potentiometer can go faulty and needs checking.
Your suspension issue will probably be a faulty air bag or valve block, and if you don't sort it your compressor will give up also. Check the bags with some soapy liquid and see if there are any bubbles. Typically this comes from the very top. Park on level ground, put the vehicle in extended mode and carefully apply the liquid to see.
Feb 10, 2010 | 2002 Land Rover Discovery Series II
Engine cuts out at 8000 rpm in any all gears
check your tank breather hose for any blocks or kinks - also have a look at the fuel filter and airbox.
Apr 10, 2009 | 2001 Yamaha YZF-R1
Garden Logo
631 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
