Question about Garmin nuvi 200W GPS Receiver
My nuvi 200 acts as if it is plugged into a computer when actually plugged into a car charger
  • 2 more comments
  • jedr2313 Sep 08, 2009
    I have the stock garmin car charger. With the unit turned on, I then plug the car charger (both ends) in and the screen defaults as if it is plugged via usb to a computer showing a picture of the unit and a computer connected via a cord at the bottom of the screen. the unit operates fine on the internal battery, just not when plugged into the car charger.
    Yes, the charger has Garmin written on it
  • jedr2313 Sep 09, 2009
    The nuvi 200 defaults to the screen which shows a gps connected to a computer with the garmin logo in the middle, just as if it is connected to a computer when plugged into a car charger. the car charger is a garmin brand.
    I tried that a couple of times with no luck
  • Garmin Master
  • 6,487 Answers
What you can do here first is tor eset the unit by pressing the reset button for 10 seconds and then power it off for 10 seconds and then check it after that...
Posted on Sep 09, 2009
  • Mark Gil
    Mark Gil Sep 09, 2009
    Better connect the GPS to your computer and do a software update and hopefully it will be detected...
    Top Expert:
  • Garmin Master
  • 75,197 Answers
Please explain what u mean? have this unit and not sure what u are saying here about the screen display, it should say battery charging if turned off when plugged to charger in a car, do u have the stock Gamin car charger? an incorrect mini usb connector (the wiring is different) can cause this
Posted on Sep 08, 2009
  • yadayada
    yadayada Sep 08, 2009
    is this a Garmin car charger?
How do you shut the garmin nuvi 200 down I can't get it to shut off
Plug it to your power charger (connected to the el-net, of course). After the map loading has completed and you can start using it, unplug from power. A dialog box will pop up and ask you either to turn it off or to continue using it on. Choose to turn it off.
You will not be able to turn it completely off as long as it's connected to either a computer or a charger.
or you on/off push button is not working and needs to be repaired.
On my nuvi 200 the push button is a bit loose, and it easly turns on when I carry it in my pocket. Some adhecive tape will keep the button in place.
Aug 05, 2010 | Garmin nuvi 200 Car GPS Receiver
When plugging into car outlet Garmin 200 goes into computer interface mode
You have to use a car charger with sufficient power capacity for your Nuvo 200.
I've used a mini USB car charger that came with my e-trex, but it works only some times when I do plug/unplugging during map loading (manipulating the computer mode setting). So, I bought a HTC mini USB care charger, and know the problem is solved. Another alternative is buy from Garmin Store, the type they recommend.
May 30, 2010 | Garmin nuvi 200 Car GPS Receiver
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
My Garmin Nuvi 200 thinks it is connected to a computer when I plug it into my car charger. WHY??
I have the same problem. Works fine on it's own, but when it is plugged in to the charger it goes to a black screen with a computer symbol. I thought that it was to tell me to update the system as it is just over 1 year old. But not sure. I then have to keep on unplugging it and plugging it back in. (comes on while plugged in randomley). Hope we get some feed back as I need the garmin all day every day.
Mar 02, 2010 | Garmin nuvi 200 Car GPS Receiver
Have a phone charger 12 volt that fits and charges the nuvi 200 but with it plugged in it wont show anything but a computer and nuvi on screen. unplug and it works but only for a while til needs a new...
thats because the phone charger is wired different to the gps charger , u need a genuine charger, if when pluged into pc it takes longer to charge, best to have gps turned off while charging from pc..... if it still does not work/ hold charge battery in unit gone , caused by being in active for over 3 months
Dec 29, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200
Guys go to
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=104952
http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
they have the answers
it seems a standard or phone USB cable will not work to charge and use the maps at same time
Good luck
Nov 15, 2008 | Garmin nuvi 200W GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 200 GPS
We did not have a charger to plug in the GPS to charge, so my husband plugged it into a battery charger. I guess the battery charger was low, so it drained the unit rather than charging it. It was so low it would not come on again. I have an electric charger that adapts the car charger into AC current, so I tried that and the unit came on. Problem solved and the GPS is working again. Thanks for responding.
Jun 20, 2008 | Garmin nuvi 200W GPS
Garmin nuvi 200W GPS Receiver Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
