Question about Sony CDX-GT10M Marine Receiver AM/FM CD Receiver
Power keeps ctuuing in and out
My unit sometimes runs all day. Other times it cuts in and out steady powering on and off. It does this on all players, ie. radio , cd and satellite radio (aux) I am almost postive that this is not a power wire problem. I see no loose connections. Any ideas??
  • 8 Answers
SOURCE: sony cd car radio
if you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Posted on Dec 14, 2007
  • 3 Answers
SOURCE: Sony compact disc player initializing
Have you tried pressing hte RESET switch?? It's behind the removeable front of the stereo, use a biro or something and hold it in for a bit.
Failing that, check that there isn't a CD already in it, could be a dodgy CD?
Posted on Jan 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 19, 2009
  • 3 Answers
SOURCE: cdx-m610 no power (why)?
Replace Brown Flex Ribbon Cable, which is connected between Display and Main unit. it is a common problem, this cable gets cracked since it moves with display. Teknofix
Posted on Mar 07, 2009
SOURCE: SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Posted on Mar 08, 2009
When hooked up the sound beats in and out! Tried 2 of these units, same problem!
Are you running it through an amp? If your head unit is putting out 50 Watts per channel and your speakers are like 400 watt, the sound will cut in and out due to a power drain. Try at very low volume and see if the sound stays steady. If so, thats the problem.
Apr 22, 2016 | Pioneer DEH150MP CD/MP3 Car Stereo Radio...
My Carrier Central Air unit is not working and shows Code: 24 VAC power
Will the indoor unit run with the Thermostat fan switch set on auto?
I need to confirm that the indoor unit runs first.
Jun 03, 2014 | Carrier 38CKC036 Air Conditioner
I use this Alba television in my bedroom and usually watch it for a little while before I go to sleep. Due to the fact that it cannot be turned off completely (always on standby unless the plug is pulled...
If the tv is not a plasma unit which are expensive to run I would not be bothered completely turning off the power. I have a power supply readout connected in the mains power and Like you I believed the hype about switching every thing off but I learnt that the cost is virtually nill. to run. For a example I have 2 moniters + 1 computer+1 printer +1 tube type TV+ clocks( all on standby) + night light and the cost is .001 cents /kilowatt hour.. IT climbs to .002 cents when the 2 fridges cut in then drops back when they cut out.. Another point is when you continually switch electronic units on and off they will suffer more failure than leaving them on stand by
Aug 02, 2013 | Televison & Video
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
When we turn the power on iit only stays on a few seconds then turns off with the cst.in light flashing.. what does this mean and what can we do to fix it?? tks
I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one! Good luck!
Jan 17, 2011 | Emerson EWD2202 DVD Player/VCR
Yamaha rx-v800 turns off
Sounds like your receiver has a cold solder joint on the power board at a transistor or capacitor. Not a major repair, however, it will probably run $100 or so to pull it apart, hunt it down and fix the problem. Not sure of your problem with the DVDR. Do you have a "line conditioning, surge protection" unit? Not a Power strip or low end monster surge. Panamax, APC, Furman, make line conditioning surge units that keep your power steady and will shut down in case of voltage fluctuation in both directions. They cost from 200 to 2000 depending on the equipment you are protecting. It is a necessary component to any system. Hope this helps.
Sep 27, 2009 | Yamaha RX-V800 Receiver
My suzuki dl 1000 k5 hiccups at 2200--4300 rpm
have seen this many times on different bikes. the manufacturers have to get their bikes to pass emission (pollution) tests, and noise tests. these tests are usually done at the same rpm, therefore the manufacturers program the ecu to make the bike run weak on fuel at that rpm. causes what we call a 'flat spot'
can think of no other reason or it would do it throughout the rev range. don't forget that after a distance on neutral throttle, the fuelling will be very weak as the bike doesn't need much then anyway. usual answer is to get ecu re programmed, or fit dynojet power commander, a plug in electrical box, will sort out all the rubbish and make it run properly. do a google search for dynojet and read their stuff.
Jul 08, 2009 | 2007 Suzuki DL 1000 V-Strom
POWER LIGHT STAYS ON ALL THE TIME ON CRAIG CDV 327
The manual states that one needs to unplug the unit when not in use.
Dec 03, 2008 | Craig 731398403288
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Car Audio & Video Logo
22 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
