Question about Do It Best Tools & Hardware - Others
I pushed too-wide staples into my Do IT Best Staple hammer - can I safely disassemble the two bolts to remove them?
    Sergeant:
  • 384 Answers
The fuse is disabled, please remove bolts carefully! Don't cut the yellow wire the fues will become able and may ........
Posted on Sep 09, 2009
My bht150 bostitch is jammed
First slide off the rubber grip This will expose a pin that you will need to remove. Remove the two bolts on top of the hammer with a 10mm wrench. These bolts hold the striker plate guide. Place the hammer in a vice to lightly compress the hammer head. Remove the allen head bolt located on the end of the head. This bolt holds the striker slid that strikes the staple. Remove the pin that you see that was under the rubber grip. Just tap with a punch and then you should be able to remove it with a small set of pliers. Now slid the enter assembly back just enough so that the jammed striker slid will come in contact with the striker guide face. Turn the hammer over and strike the top of the hammer on a piece of wood. This should free the slide and jammed staple. The staple and slide will come out. Take a file and deburr the slid and add a dab of grease to it. To reassemble, Attach the slide guide first, but leave it loose. The rest is reverse order. Hope this helps.
Jan 03, 2013 | Stanley Tools Hammer Staple/Tacker -...
I have a Stanley SharpShooter PHT150 that's jammed. I would like a diagram/instruction sheet showing how to fix this problem. Thanks.
Here is a copy of the instruction manual for your stapler.
1. Press end clip in, then up.
2. Pull out spring assembly.
3. Load staples into channel.
4. Reinsert spring assembly and
snap end clip into place.
EASILY DISASSEMBLED
FOR CLEANING:
1. Squeeze stapling end of hammer
tacker together, taking care to
avoid sharp staple.
2. Remove locking pin.
3. Press end clip in, then up.
4. Pull out spring assembly.
5. Remove staple channel.
6.Clear and reassemble
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2011 | Stanley Tools Hammer Staple/Tacker -...
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
Got a staple jammed can't get out . don't know to take it apart.
This can happen all the time... first remove the slide-in tensioner which pushes against the staples. Remove the single bolt with lock nut which is towards the rear of the stapler. Now you can pivot the staple rail down and out of the gun. Just remove any twisted staples from the rail. Now reassemble the rail by positioning the front of the rail to go into the small slots in the front of the stapler body and re-attach the bolt. You may now reload the staples and tensioner and continue working. Takes just a minute or 2.
Jun 25, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Jammed staple-need to remove top of gun to remove
pull all staples out and take a screw driver and hammer drive the plunger back down into stapler till the hung staple is released
Nov 04, 2009 | Arrow T25 Staple Gun
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Compare staple guns
A hammer tacker is a device somewhat similar to a staple gun, except that the mechanical energy from the user's muscles is stored — as in a hammer — as momentum of the gun itself, rather than as compression of an internal spring. This type of stapler is typically used for insulation, roofing and carpeting.
Aug 27, 2008 | Do it Best Imports/ Jaun Yei 326409 Cable...
Tools & Hardware - Others Logo
49 people viewed this question
Top Do It Best Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Do It Best Tool and Hardware - Other Expert? Answer questions, earn points and help others
