Question about Dryers
Dryer runs but doesnt heat up. - Dryers
  • 5,911 Answers
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful. NOTE: On some dryers, the TCO may be referred to as a "Thermistor".
Posted on Sep 08, 2009
  • 631 Answers
The heating element is probably out.
It heats up but doesnt stop after the clothes are dry
IT is the timer. If electronic needs to replace the board. If dial type, needs the timer
Sep 15, 2014 | Dryers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Dryer runs, but doesnt heat up. already changed the fuses, still no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 14, 2010 | Frigidaire FER641FS Electric Dryer
On a Whirlpool, it has been for me the coils are broken...it can be fixed by undoing the belt, 'popping' the top pnl up with a screwdriver, lean the front pnl down then move the drum forward to get to the coils. You MUST use a crimp type connector as these are nickle wire and won't solder easily. Saves a lot of money and will run forever. Definitly unplug it first! Duh!
Dec 10, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
My roper dryer is not heating
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Dec 06, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Timer doesnt move while dryer is on
Please page me here so that i can get back to you
May 19, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
