Question about Air Tools & Compressors
Ingersoll rand g2 angle grinder exploded parts diagram need to find part numbers for the bevel gear and bevel pinion gear
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
Follow this link: http://www.irtechpubs.com/ir_pdfs/Tools/Finishing%20-%20Surface%20Prep/Air%20Grinders/04581237_ed5.pdf
On page 5 of this publication you will find 2 sets of bevel gear and pinions. You need to know which model grinder you have in order to get the right set. The different models are G2E, G2A, and G2L. On page 4 you will see the diagram for the right angle. You may be able to match up by sight which one you have. If you have the A or L you need to know the rpms of your model to get the right set.
Posted on Sep 09, 2009
Need a manual for a Ingersoll Rand Model 111
If you go online to Ingersol Rand, click on air tools. You should be able to find the IR-111 knuckle saver ratchet. Once there you should be able to click on a link that opens up the exploded view of internal parts. Otherwise go to your local air tool repair centre, they can help.
Feb 21, 2012 | Ingersoll Rand 111 The Knuckle Saver 3/8...
Diagram of parts
you can download ingersoll rand tool manuals and parts lists from
www.irtechpubs.com
Jan 22, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
I have a dewalt 28402 grinder. I have replaced the pinion but I don't know how to get the helical gear out of the case to replace it. Any thoughts? Thanks Chris
You can buy the pinion gear as a seperate part but not the ring gear. Dewalt only sells the ring gear as a part of the gear case assembly, PN 623586-00.
Oct 28, 2010 | Dewalt D28402K Heavy Duty 4 - 1/2" Small...
How do you know what ratio a subaru wrx gearbox is if it doesn't have a trans code sticker on it?
This information is from my genuine service manual. I hope it is of help.
Non-turbo
Turbo
Sedan Wagon
Type 5-forward speeds with synchromesh and 1-reverse
Transmission gear ratio
1st 3.454 3.454
2nd 2.062 1.947
3rd 1.448 1.366
4th 1.088 0.972
5th 0.780 0.738
Reverse 3.333
Front reduction gear Final
Type of gear Hypoid
Gear ratio 4.111 3.900
Rear reduction gear
Transfer
Type of gear Helical
Gear ratio 1.000 1.100
Final
Type of gear Hypoid
Gear ratio 4.111 3.900 3.545
Front differential Type and number of gear Straight bevel gear (Bevel pinion: 2, Bevel gear: 2)
Center differential Type and number of gear
Straight bevel gear
(Bevel pinion: 2, Bevel gear: 2 and viscous coupling)
Transmission gear oil GL-5
Transmission gear oil capacity 3.5 2 (3.7 US qt, 3.1 Imp qt)
Mar 21, 2010 | 2007 Subaru Impreza WRX Sport Wagon
Need exploded diagram of ingersoll rand Model 8049 electric impact wrench in order to order a planetery gear kit
Here you go... I needed the same...
http://www.powertoolrepairohio.com/pages.php?pageid=14&breakid=1118
Feb 22, 2010 | Ingersoll Air Tools & Compressors
I have an IR 231 Model A. The set screw under the trigger came out along with what I assume a spring and ball. I need these parts, but more importantly I need an exploded view of this tool. There are...
This is the Model A, break down part numbers..go to sheet 25 for the exploded view with numbers.
http://www.irtechpubs.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/P6169eu1.PDF
Dec 30, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
I NEED A PART FOR MY INGERSOLL RAND IMPACT WRENCH . IT IS THE LITTLE HOLDER ON THE END OF THE DRIVE THAT HOLDS THE SOCKET ON. IR MODEL NUMBER 1702P I CAN'T FIND A SUPPLIER THAT HAS AN EXPLODED VIEW OF THE...
You will probably have to get it from a company service group for the product.
USUALLY this part is just a circle of spring wire. You might be able to either get some spring wire, often refered to as "Music Wire" and make your own OR you often can buy regular springs from hardware stores and with a grinder cut a coil from the spring and form it slighlty to fit.
The circle of spring fits fairly loose so the sockets have to be pushed over it with a little force.
Nov 12, 2009 | Cars & Trucks
Air Tools & Compressors Logo
529 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
