Question about Canon Office Equipment & Supplies
My bjc printer won't print. The paper goes through. The head/cartridge moves like it is printing but nothing. Tried everything in the maintenance manual.
  • Canon Master
  • 32,281 Answers
If you have fresh ink cartridges installed and you have run the head cleaning maintenance and still have problems then the problem is most likely the print head ink nozzles are blocked.
This occurs then the printer has not been used for some time. To keep the nozzels from blocking the printer should be used once a week or the clean head maintenance run weekly.
There is no option other than to buy a new print head, they are not cheap.
Posted on Sep 09, 2009
Bought used BJC-85 - feeds paper - won't print with new cartridge. Must have been dry too long. Where do I get a print head for it? Or a cleaning kit? I need it right away for a trip.
No need to change the print head. Just carry out all the maintenance tasks with the new cartridge. Make sure that you remove the thin plastic film from the ink pad. All you have to do is to click on printer/faxes in control. Click on properties in the drop down menu. Click on the maintenance and carry out each task i.e. print head cleaning, alignment, nozzles cleaning etc.
May 12, 2010 | Canon BJC 85 InkJet Printer
Canon BJC-3000. Paper goes through but is blank.
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 24, 2010 | Canon BJC 3000 InkJet Printer
BJC 85 not printing after head replacement
I have similar problem. Print head won't print, then I clean with alcohol, and get rid of old ink inside. But then head seems to just shut down. I have several print heads and printers that have plenty of ink, but head won't work. I refuse to think the print head will break so easily. I used my BJC 85 for YEARS with no problem whatsoever, and suddenly, since last winter, I have 4 printers that have stopped printing.
I usually end up just buying another used printer on ebay until that one stops printing.
Terry tlworkroom@lycos.com
Feb 28, 2010 | Canon BJC 85 InkJet Printer
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
No yellow printing from my color cartridges
The nozzles that the yellow ink flows thru are clogged. Try the print head cleaning utility. Right click on the printer, select PROPERTIES, select the MAINTENANCE TAB and press the PRINTHEAD CLEANING button. If that doesnt work, turn off printer, open front cover and move the ink carriage toward the center. You should see a small rectangular cotton sponge pad thats covered with old inks. Put several drops of Windex on it so that its nicely soaked and return ink carriage. Turn on printer and run the print head cleaning utility again. Then let it sit overnight. The next day, try printing a test page.
Jun 17, 2009 | Canon BJC 1000 InkJet Printer
Printing black text
you can try this to really clean the print head: Canon will hate me for this.
1. Remove ink cartridges.
2. Remove print head.
3. Go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head being careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air-dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Feb 16, 2008 | Canon BJC S450 InkJet Printer
CANON BJC-85 Won't print black...
Turn on printer, press cartridge button, remove cartridge. On left side of remaining cradle, unsnap the cradle, lift up and remove. Take the cradle to your sink, wet a paper towel, and GENTLY wipe the long print head with the wet paper towel. Then run a small stream of clear cool water through the cradle, from the round pad that your cartridge rests on, until the pad looks ink-free. Dry everything with tissues and a hair dryer set on low, replace cradle in printer, replace cartridge, turn on printer, press Resume until it beeps three times, which runs the deep cleaning program, and after the procedure is finished, your printer will print as new.
Apr 14, 2007 | Canon BJC-85 InkJet Printer
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Nov 12, 2006 | Canon BJC 80 InkJet Printer
63 people viewed this question
old marine
old marine
