Question about Kenmore Elite HE4 Electric Dryer
Dryer Rack I need the owners manaul or instructions on how to install the dryer rack I have the Kenmore Elite HE4 dryer
    Problem Solver:
  • 14 Answers
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Posted on Jan 20, 2009
  • 2 more comments
  • Cheryl Hofeld
    Cheryl Hofeld Jul 16, 2014
    I have the 3 positions too. When I put it in F...it's too short, H doesn't have a hole and A is too long. I am so confused.
  • Michael Armstrong Jul 16, 2014
    I just tried mine again and had to be re-trained. The key is to assemble the wire frame onto the plastic rack and then put the whole mess into the dryer. It doesn't look like it's going to work, but it does.
    I added some pictures to my original post which may help (or not). They didn't get inserted in the right order, but here's what they are:
    1- Rank and frame assembled; 2- Rack and frame; 3- Frame being placed into hole(s) in rack; 4- Frame folded down, but not locked into rack; 5- Frame and rack snapped together; 6- Going into dryer; 7- Frame resting on back of drum, rack resting on lint filter.
The dryer rack is shipped in place in your dryer. Remove and
discard any packing material before use.
Use the TUMBLE FREE Heated Dryer Rack for items that you
do not want to tumble dry, such as sweaters. When you use the
heated dryer rack, the heated air inside the dryer flows in a
concentrated pattern to allow efficient and uniform drying.
Use Timed Dry to select the desired time.
NOTE: Do not use Auto Cycles with the dryer rack.
To use the heated dryer rack:
Do not remove the lint screen.
1. Open dryer door.
2. Place dryer rack over the bottom of the dryer door opening.
Rest the back wire on the dryer back ledge. Push down on
the frame front to secure over lint screen.
3. Place wet items on top of the rack. Allow space around items
for air to circulate. The rack does not move, but the drum will
rotate. Make sure items do not hang over the edges or
between rack grille.
4. Close the door.
5. Select TIMED DRY and MORE TIME or LESS TIME. Reset
time as needed to complete drying. Refer to the following
table.
6. Select the desired temperature setting to match the fabrics in
your load by pressing TEMPERATURE. Items containing
foam, rubber, or plastic must be dried on a clothesline or by
using the Air Dry temperature setting. Refer to the following
table.
7. Start the dryer.
NOTE: You must remove rack for normal tumbling. To remove the
dryer rack, lift it straight up and out of the dryer.
NOTE: Check the lint screen and remove any lint accumulated
from items dried on the rack.
Suggested Items for Rack Temperature Suggested
Drying Setting Time*
(Minutes)
Washable wool items (block Low 20
to shape and lay flat on
rack)
Stuffed toys (cotton or Low 20
polyester fiber filling)
Stuffed toys (foam rubber Air Dry 50
filled)
Galoshes (rubber) Air Dry 20
Foam rubber pillows Air Dry 50
Tennis shoes Air Dry 20
*Reset time as needed to complete drying.
You can get all of this and pictures at www.managemhome.com.
Posted on Dec 11, 2007
  • bmaxx Dec 11, 2007
    Correction: www.managemyhome.com
    New Friend:
The wire legs are adjustable. Flip the rack up side down and squeeze the wire legs towards each other then swivel them to remove them. Adjust the legs to "A" position (There are 4 positions-mine fit the "A" position) so that the horizontal wire leg fits across the back ledge if the dryer.
Posted on Dec 31, 2012
EXACTLY!   I tried the same... It will not clamp down... and yes...  IS THERE SOMETHING MISSING??
Posted on Dec 15, 2008
  • Coereen Dec 15, 2008
    〈Push down on the frame front
    to secure over lint screen.〉
    THIS DOES NOT WORK
I have the same issue. However after following the instructions, to the "T," the rack will not clamp down, is there somethign I am missing?
Posted on Jun 29, 2008
How to install dryer rack in kenmore HE3 dryer
Open your Kenmore HE3 dryer door. Look for the ledge on the inside rear of the dryer wall.
Insert the rear wire leg of the dryer rack into the drum, resting the wire leg on top of the ledge. The front frame should rest over the dryer lint screen.
Push down on the top of the front frame of the dryer rack to secure it over the dryer lint screen frame. Close the dryer door once you load your items on the rack.
Feb 02, 2013 | Kenmore Dryers
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
How do I install a dryer rack in my Kenmore Oasis Elite Dryer?
The rack goes in thru the door and rests on the back panel usually in small slots and just behind the door.
Sep 18, 2009 | Kenmore Elite HE4 Electric Dryer
I cannot figure out how to place the dryer rack.
Try here.
http://www.devicemanuals.com/guide/Dryer/Kenmore%20Elite/Kenmore-Elite-11067052600-Residential-Dryer-Use-and-==TWpjM01URTM=.html
Sep 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer rack installation
I had the same problem: they sent me the rack, but no instructions.
But if you look in the product manual for your dryer, there should be a section on how to use the rack. For the Cabrio, which is what I have, it's on page 21.
If you don't have the manual anymore, you can get them online at Whirlpool's web site. Just plug in your model number in the search box, and there it will be.
Feb 26, 2008 | Whirlpool Cabrio WTW6600SBK
Kenmore Elite HE4 Electric Dryer Logo
4,648 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
