Question about Campbell Hausfeld 28 - Gallon Air Compressor
I have a 30 gal 125 psi 5hp air compressor and It will not pump up. I took the top off and I noticed the line from the pump to the tank was loose so I tightened it and it still wont pump up.It seems to me that the rubber seal on the lines are bad but the one side looks good.I have called two different dealers and they wont return my calls. I need to know what to check and how to check it so I can get this fixed.How can I tell if the pump is good? Also where can I get parts?
  • 631 Answers
Take the outlet line off of the top of the compressor and turn on, if you feel a substantial amount of air coming out of the compressor then the compressor is probably ok.
Posted on Sep 08, 2009
Testimonial: "There is not a lot of air coming out but there is some air coming out. The air isnt very strong that is coming out. How can I tell if the pump is righ"
  • 227 Answers
Here is the website that will have the parts you need and also have an exploded parts diagram and part number list for your model ac. I am sorry if I cannot give you any more information. All I hope is that the link below gets you to where you need to be:
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
Good Luck and best of wishes with your air compressor.
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
I R Ts4 5hp 80 gal 175 psi 230 volt Air leaking from near pressure switch. Replaced switch but still leaking near 1/4 tubing. Thanks
You have a receiver tank check valve leaking. If you loosen the 1/4 tube slightly and air blows out more and will not stop replace the tank check valve. If you follow the copper line for the compressor HP head back to the tank you will see that the line screws into the check valveand the check valve screws into the tank. Bleed all air from the tank,remove the 1/4 line and the 3/4 line from the check valve. Then unscrew the check valve. Install a new check valve and connect the lines. Problem solved.
Apr 30, 2011 | Ingersoll Rand 2340/2475 Electric Air...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a sears craftsman air compressor 5hp 22 gal tank single cyl oil free it gets up to 70 psi does not shut off but will go no higher i cant find any leaks just bought it used guy used it to paint i...
The regulator and emergency release valve need to be checked. It should shut off once the PSI hits the target pressure. If the motor is staying on and the pressure never raises above 70 lbs, then air is escaping, either the emergency prv or a seal has blown
Sep 24, 2009 | Air Tools & Compressors
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 28 - Gallon  Air Compressor Logo
303 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
