Question about HP Officejet 5510 All-In-One Thermal Printer
Hp 5510 office jet all in one pushed the button below the number or key pad and shut off no power even if connected. adapter work great , not sure if its thermal model
I want to type in numbers instead of letters
it works like older cellphone models where in you have to keep on pushing the letter key or button until you get to the number you need.
Jun 11, 2011 | HP J4680 Office Jet All-In-One Printer
How to change the cartrige for hp 5510; chere are the cartgages stored in the pinter. I do not have a manual.
Here is the link to download a copy of the manual for the HP 5510 All-in-One Office Jet Thermal Printer at HP.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=311255&
Step-by step instructions along with illustrations on how to replace the print cartridge is found on p. 63
Apr 20, 2011 | HP Officejet 5510 All-In-One Thermal...
Hp office jet 5610 all in one printer--- am I able to fax without hooking up to a computer if yes how- thanks
All the HP office all-in-ones fax without computer hookup, simply place the fax on the load tray face up until you see the window state that the original is loaded. Then on the number pad dial the fax number you want to connect to, once that is done...press the black fax button and the machine will dial the number, once a connection is made the fax will feed itself through and complete. The only connection needed is an outgoing phone line. Just make sure that the phone line is in the right socket on the back. You will see icons by the sockets, the one with the phone icon is for a line to go to a phone headset....this is not the socket for the main phone line, ise the other one that says "line".
Jun 27, 2010 | HP Officejet 5610 All-In-One InkJet...
The Copy, Fax and Scan buttons are flashing (all at once) and when I push one to select the function it says busy ? Its a Hp officejet 5510 all in one printer.
pritner is dead , you can try a reset by the steps below.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
If it does not work then , you have to go for a new printer.
Apr 08, 2010 | HP Officejet 5510 All-In-One Thermal...
Printer cartridge error message for office jet 5510 printer
I JUST HAD ADVICE FOR ANYONE THAT IS HAVING INK PRINTER CARTRIDGE PROBLEMS WITH THEIR HP 5510. MAKE SURE YOU ARE USING GENUINE HP INK CARTRIDGE. I HAVE BEEN HAVING PROBLEMS AND THE HP HELP DESK SUGGESTED THIS. NOW IT WORKS PERFECTLY!!!! JUST WANTED TO SHARE THIS INFO IN CASE ANYONE ELSE IS HAVING PROBLEMS!
Dec 11, 2008 | Office Equipment & Supplies
Code error 021 not in book inforation codes
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you - nothing will appear on the screen) - so count the beeps)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax (and cross fingers)
Jan 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
HP Officejet 5510 All-In-One Thermal Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
