Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printing problem and paper jams
I just put in two new print cartridges and my printer no longer prints black or magenta. I have cleaned the heads and ran an alignment without resolve. any suggestions. also, as of last night started giving me the error message that there is a paper jam. How can I safely remove the paper when jammed?
  • Anonymous Dec 13, 2007
    Copies have been showing up with a vertical line the length of the page. As of a few days ago I have copies with 2 vertical lines about 2 inches apart. Why? Have cleaned the printer but no change.
  • 57 Answers
I understand that you are receiving Paper Jam error on the printer front panel of the All-in-one.
This issue may occur because of dirty rollers and is unable to feed the paper.
Please follow the below given instructions to resolve the issue.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Clean the Paper feed rollers by following the below given instructions:
Here are the steps to clean the rollers :
1)Turn off the all-in-one.
2)Unplug the power cord from the back.
3)Remove the rear access door .
4)Clean the rollers one at a time using a clean cloth that is slightly dampened with clean water (preferably distilled water). Rotate the roller to clean the entire surface.
5)Verify that the three paper feed rollers on the rear access door are clean and rotate freely.
6)Reinstall the rear access door and then plug the power cord back in.
7)Turn the all-in-one back on
Clean the print cartridges by following the below given instructions:
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
If you are receiving the paper jam error on the computer, then follow the instructions from the below given article in order to resolve the issue.
Here is the web document:
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Even if the issue persists, try refreshing USB composite devices to get the issue resolved.
1. Right-click My Computer (in Windows XP, click Start first), and then click Properties.
2. Select the Hardware tab and then click Device Manager.
3. Click the Plus (+) sign next to Universal Serial Bus Controllers.
4. Click the USB Composite Device entry to highlight it, and then click Action and then click Uninstall. If a screen appears to confirm the deletion, confirm the deletion.
5. Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
6. A New Hardware found screen may appear, click Next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
Hope the information provided will be helpfull in resolving the issue.
Posted on Jan 10, 2008
About a month ago, I bought new cartridges for my Epson NX400. It will print every color but the black ink on the test pages and on the things I print out. However, I have only printed one page since I got...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Nov 25, 2010 | Office Equipment & Supplies
My printer is not printing magenta. I have changed the cartridge (hp one), cleaned the print heads and
The magenta print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked magenta print nozzles. Also check the magenta cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Computers & Internet
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the...
this rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Printer cant print in black and white
This happend to me also and I finally found out that the printer uses collor cartidges for GRAY printing. The back cartridge is used for BLACK printing ONLY. So if the printer was short of one collor in my case it was magenta (red) the gray parts of BW prints started to be green!!! When I put new magenta cartridge to the printer gray was gray again...
Mar 03, 2009 | Canon MP610 Photo All-In-One Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Brother DCP-120C Printer - Does not print black, Black and magenta cartridges renewed with new Brother cartridges. Black ink level reset OK but not magenta. Have tried automatic head cleaning but still no...
have you recently had a paper jam. somtimes pieces of paper can become trapped under the print head which restricts the printing. if there is and its been there for a while the print head may need to be wiped/cleaned( a bit tricky) then a couple more print head cleans.
Nov 04, 2008 | Office Equipment & Supplies
One color
yep, print head needs proper clean, here it is.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 29, 2008 | Canon i860 InkJet Photo Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
116 people viewed this question
Ben Johnson
