Question about Goodman CLQ36AR49 Air Conditioner
Goodman Model # cpke241AB not cooling always running
Goodman Model # cpke241AB we are in need of cleaning our evap coils and blower wheel where are these located? do you have diagram?
no freon is needed per a/c
  • 92 Answers
First locate the air handler.Open the access panel and you will see the evap coil.You will clean the coil in the unit,I use a wire brush and coil/evap cleaner.I dont typically clean the blower but if you must there will be 2 or 3 screws and some electrical that you will need to disconnect.then the blower assembly will slide out and you can clean it outside,Note where you disconnect the electrical connections --good luck!
Posted on Sep 09, 2009
Testimonial: "Thank you !! It worked! The A/C is running and the cost of the cleaner $11.00 (home dep) ~vs~ $325.00 that AIR ZONE A/C in Oldsmar, Fl wanted to charg"
I have a Goodman Heat pump system Model ARUF061-00A-18 And the Blower wil work in the Heat mode but not in Cooling.
Sounds like a bad relay. Unfortunately that relay is on a circuit board. You can bypass the board, I will help you if it's actually the case. But, to test it, turn power off to unit, on the circuit board you will have a relay(In the indoor unit) on this relay you have three wires, swap the two wires that are right next to each other. You will see 2 wires very close to one another and another off to the side. Swap the 2 that ARE RIGHT NEXT TO EACH OTHER. Turn power back on to unit. This should make the fan run non stop all the time. If it does let me know.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 03, 2017 | Goodman Heating & Cooling
Pieces broke on blower wheel, where can I get and replace? Also need to clean coils. Live in FL, always running.
You will likely need to call the manufacturer with the model number of the indoor unit. To clean coil use a mild soap with machine off. Be sure to rinse coil clean with water to avoid bubbles entering the blower motor upon start up. I use a paintbrush with the bristles cut short for extremely dirty coils. Be sure to brush WITH the fins, NOT side to side.
Apr 11, 2017 | Heating & Cooling
Freezing up on goodman air condition cple36-1
Hello, freezing up is either a airflow problem such as dirty filter, dirty evap coil, dirty blower wheel, wewk blower motor ot a low refrigerant charge.
Jul 24, 2012 | Heating & Cooling
I have got a gree 60000btu under ceiling unit, the suction pipe is icing up back to compressor its running on 360kPa suction and if I top up the refrigerant it does not change
major causes of evap.freezing dirty coil,evap fan motor or capacitor low on freon.moisture in system. first turn off cooling run fan to completely thaw unit. if possible clean coils and blower wheel. any unit running efficiently the evap coil will be at freezing or below. the key is to have enough airflow across the coil to remove the heat and humidity.its very easy to introduce air and moisture into the system. i have seen alot of techs. over the years make the same mistakes over and over again. when hooking up guages they dont purge the lines back; worst case is only to evacuate freon pull a vacume and recharge
May 22, 2012 | Heating & Cooling
Goodman model PGB036075-1B will start the gas and the burner but will shut down before blowing heat. Is it a bad switch?
Hello, sounds like either a dirty flame sensor or open limit switch. First try cleaning the flame sensor by turning power off to the furnace and using some steel wool. If the flame sensor checks out good then you limit switch is opening becuase of lack of airflow. check air filter, clean blower wheel, and check to make sure the blower wheel is running at proper speed and not dragging sometimes cause by a weak capacitor.
Mar 06, 2011 | Goodman Heating & Cooling
Central air only blows a small amount of cool air out the vents. After running 12 hours it only cooled my small 1BR apartment 3 degrees. The filter has not been replaced since October 2009 but I can't seem...
I have a Goodman A/C unit APRF036-00B1. The out side unit seems to be sucking and bowing air, the coil is cool to the the touch and the blower seems to be turning. I've check what seems to be the obvious. A small amount of air is only coming out. Any suggestions?
Feb 21, 2011 | Goodman CKL36AR36 Air Conditioner
Freezing Goodman pipes
make sure the filter is clean. also the evap coil should be clean. if none of these then your system is probably low on charge. hope this helps
Jun 05, 2010 | Goodman CKL42AR42 Air Conditioner
GSH13 Goodman heat pump split system is running a long time in cooling mode and will not cool below 74 degrees. A lot of condensation generated. The low side pressures 78 to 81 and high side pressures are...
Check sub cooling and super heat. the New ac units are very critical to charge. There is a charging chart on the inside of the cover to the unit outside. Check temp difference across coil. Should be 18 to 22 degress. If you have an ampmeter. Check the heat strips one 5 kw might be stuck.(sequencer). This would cause you not be able to pull down temp. Goodman unit are hard to charge to get the temp difference across coil. Feedback please
Jun 14, 2009 | Goodman CLQ36AR49 Air Conditioner
Blower squeak! Bearings or Bushings? Can it be greased?
Most elec. fan motors can not be oiled , try holding the blower assembly with the fan running to see if that stops the noise , if it does not you need to replace the evap. fan motor and if the blower wheel is dirty clean it , if there is alot of rust on it replace it as well. Good luck.
Dec 30, 2008 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
662 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
