Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
How do you program mxz4a36na with 3 zone dont have the right code at outdoor unit how can i restart from the begining red light and yellow light stay on no green light to program
  • 1,238 Answers
Http://www.mrslim.com/customerCare/resourcesDetail.asp
Go to this web site. It has bunches of manuals an info on your unit. Just look for your specific. Good Luck
Posted on Sep 12, 2009
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Why isn't the timer going off/changong zones?
Go to the Intermatic website and download the instructions. There may have been a design change. If possible, compare old and new instructions.
Jun 19, 2015 | Intermatic T8845PV - Sprinkler-Irrigation...
We have a 1998 frigidaire furnace. M#FG6RA 072C-12A. It has a mind of its own! there is a red light that flashes 3 times.
Check the electrical panel cover for the schematic and see if the flashes are listed with their troubleshooting codes. If not check any documentation that came with the unit, or go on the internet and do a Google search.
Nov 06, 2013 | Frigidaire Heating & Cooling
L dont have right 4-digit code for daewoo, the codes i have,dont work
Try these codes.
0130 0004 0009 0100 ................. 0005 0138 0043 0140 0039
....... 0252 0279 0444 0080 0042 0058
....... 0017 0010 0126 0018 0127 0019
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method.
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 17, 2012 | Televison & Video
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Apr 25, 2011 | LG Heating & Cooling
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
PS3 won't stay powered up.
powersupply is bad. ebay has them for around 45.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Loss of sound after i start the angine
red - switched power (hot when key is on)
yellow - constant power (hot at all times - depending on the vehicle, i've used a direct battery connection, but isn't recommended)
black - ground
blue - power antenna or amplifier 'REM' wire
the other's, i'm working off of old memory....
purple - rear right
green - rear left
white - front right
gray - front left
wires with black stripes are ground, and without are hot
- if you're working on an older car, it sounds like your red and yellow are connected to the same power source. if this is the case, the time will always be resetting.
- if it's a newer vehicle, AND the time is not resetting, the red wire is connected to the wrong source. if the time and stations stay programmed after it shuts off, the yellow wire is correct.
Feb 03, 2009 | Sony MDX-CA580 MiniDisc Player
Bosch tassimo
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Programing universal remote
Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
Jan 20, 2008 | Televison & Video
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
130 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
