Question about Canon Rebel XT / EOS 350D Digital Camera
Camera will not turn on
My Canon EOS Rebel XTi will not turn on at all. When I install the memory card, the little red light on the bottom "CF" flashes and the camera is dead.
    Sergeant:
  • 161 Answers
Try changing batteries is the first thing you should try, the memory card isn't really important if your Eos isn't working.
If your Eos works, try looking on the lcd screen. It should give you an error code. Go to canon's website into the camera section and look up the code.
If that doesn't fix the problem, if you are still under warranty, I would suggest you to contact Canon for fixing it. If your under warranty, it should be free. If your not under it, you might need to pay.
Posted on Sep 09, 2009
My canon rebel xti will not power up with a cf memory card in place. I tried two different cards. With no card in place it works fine.
check for bent CF pins. Also remove the back cover and make sure the bottom right rear circuit has not come loose and is not shorting out the board
Oct 13, 2013 | Canon Digital Rebel / EOS-300D Digital...
I have a canon eos rebel xti and the Compact Flash CF Card Reader is broken. The little metal prongs broke off when the memory card got put in wrong. How much to fix this?
If you are referring to the camera the job is up to a repair facility if it's an optional card reader used to transport data to a computer then buy a new reader.
Going back to the camera "normally" a fix like this "depending where in the world you are" will run about $120.00 CDN including the shipping
Apr 29, 2011 | Canon EOS Digital Rebel XTI Digital Camera
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
I have a CF err on my Canon Rebel XTI EOS
If your camera uses a compact flash card, then something is wrong with it. Possible causes: card needs formatting in camera (this will erase it) one or more pins inside camera are bent. Card was erased or formatted on computer instead of camera.
Feb 19, 2010 | Canon Rebel XTi / EOS 400D (body only)...
Why does the word, ''busy'' pop up on the canon rebel xti?
This is the camera writing to the CF memory card. Perhaps your card is a lttle slow, so you will see the message. I use the Sandisk Ultra II CF, labelled as 15Mb/sec and it is very very fast indeed - I don't have any lag with my XTi. Try a different CF, if it is fast enough, the message will go away. Ensure you format the card on the camera too.
Apr 13, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Canon eos 400d. card empty but cf light flashes red
Hi! Rachel, Mark here see if i can help.
Try different cf card see if it works.
Next if that worked or not take cf card place in computer & format card. Retry in camera.
Hope that fixed ya if not comment back me happy to assist you further. Good Luck! please rate.
Mar 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Lost previous pics after checking used memory on CF card
have you used the card since if not there is a program you can download that can help recover the datahttp://www.pcinspector.de/Sites/smart_recovery/info.htm?language=1
Feb 23, 2009 | Canon Rebel XT / EOS 350D Digital Camera
New canon eos digital rebel xti
There have been several reports of CF cards that work with all cameras, except the Rebel XTi. It depends on the actual manufacturer of the card. Canon made a change mid-production that affected the data saving. Try another brand of card & you should not have that problem any more.
Jun 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel won't turn on, red light next to "CF"
Assuming you have tried another card you know to be good...
Remove the memory card, main and backup battery, switch the camera on for 10 mins. While you are waiting look into the memory card slot with a torch and make sure none of the pins at the bottom are bent.
If there is this will mean opening the camera to straighten it or sending it in for repair.
If not refit backup battery and main battery and cross fingers..:)
best of luck
May 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
240 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
