Question about Dell Latitude D600 Notebook
Older dell latitude 600 lcd screen is on but is pink where it should be white. It is also fuzzy and hard to read letters in the pink
  • Dell Master
  • 4,806 Answers
Sounds like the cable to the inverters has worked loose. Sometimes repositioning the laptop lid resolves the problem but the problem still persists.
The inverter is located underneath the screen itself and is a long, elongated circuit board with wires protruding from each end. To get to it you have to remove the screen bezel (the plastic screen surround).
Check the connections on the inverter and make sure they are plugged in tight.
Hope this helps.
Posted on Sep 09, 2009
  • 3,940 Answers
Reseat the LCD cable, see if the connection works any better. Next try an external monitor. If colors are good on external, replace motherboard
Posted on Sep 08, 2009
PINK Laptop screen
1. Plug in an external monitor to your laptop. If the picture on the external monitor is good, then the problem is your laptop screen. If the external monitor also displays a pink screen, the problem is in your laptop hardware or software.
  • 2 Contact Dell if your computer is still under warranty when the problem is with your screen. If your laptop is not covered by warranty, contact a computer repair shop to have the screen repaired or replaced.
  • 3 Update your drivers and bios. Outdated drivers or bios have been known to cause screen issues. Visit Dell's Drivers and Downloadsicon1.png website where you can enter your service tag and find the appropriate updates for your computer.
  • 4 Contact Dell's technical support team if the above steps do not fix the pink screen. Dell has had known issues with the pink screen being caused by the graphics card on some of their laptopsicon1.png. In many cases, replacing the motherboard is necessary to remedy the problem.
  • Read more: http://www.ehow.com/how_6318059_fix-pink-screen-dell-laptops.html#ixzz2n6yCxzw5
    Dec 10, 2013 | Dell Latitude E5500 Laptop
    Screen is dark
    try connecting a external monitor and see still its dark on the video or else then the LCD needs replaced
    Jan 12, 2010 | Dell Latitude D600 Notebook
    My dell latitude 600 decided to not recognize its hard drive, I got another one and it wont recognize it either. Any ideas
    1. Turn on the laptop
    2. press F12 repeatly until you get to a screen with option
    3. Navigate to Hard drive Diagnostics screen and select it
    4. If this comes back failed you indeed have a bad hard drive.
    Oct 15, 2009 | Dell Latitude D600 Notebook
    My display is pink & fuzzy.
    You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
    Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
    Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
    The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
    Check out
    www.lcdparts.net
    for parts, repair service and DIY info.
    Aug 12, 2009 | Dell Computers & Internet
    Dell latitude d610 dark screen
    there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly  you should go to service and need to be changed INVERTER.
    pls rate
    May 28, 2009 | Dell Latitude D610 Notebook
    My dell latitude D830 display colors have faded.An
    I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
    Mar 12, 2009 | Dell Latitude D830 Notebook
    My dell ppo1L C/600 latitude won't boot
    hello, seems like your hard drive have errors. replace the hard drive and reinstall the computer and your computer gonna work.
    Mar 10, 2009 | Dell Latitude C600 Notebook
    Dell Latitude
    If the system still works on an external monitor and functions normally otherwise, you might be able teo replace the LCD assy for about $150.
    If the system no longer works on external either, then I'd say the system is no longer viable as an item to repair as it will be cheaper to replace it then to repair it. (New laptops start at around $500)
    Feb 08, 2009 | Dell Latitude CPX Notebook
    The laptop starts up with a pink hue
    Make sure the LCD is completely attached to the system board. I've had them come partially out and cause this. If this doesn't help, your LCD and/or inverter could be going bad.
    Dec 30, 2008 | Dell E176FP 17" LCD Monitor
    Lcd inverter--need to replace
    They aren't hard to replace. If you can find one on eBay, get it and use the on-line manuals from Dell's web site. They are very clear and easy to follow.
    Dec 24, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
    Dell Latitude D600 Notebook Logo
    321 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
