Machine knocks in Wash cycle - Washing Machines
  • sphinx20060 May 11, 2010
    What model is it? Is it a front load or top load?
  • yadayada
    yadayada May 11, 2010
    make and model number please!
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Knocking during wash and spin cycle
I woulds let a repairman look at your machine. Your rubber dampers are broken and your machine will shake itself to bits if you don't address this problem.
Mar 07, 2014 | Computers & Internet
My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
Jun 12, 2011 | Westinghouse Washing Machines
Washing machine startee knocking loudly on spin cycles
this is usually an indication that your tub is off balance you need to stop the cycle let is come to a stand still and once it has stopped spinning then shift the clothes around to evenly distribute them. or remove some as it may be over filled and will not wash well if it is over filled. off balance can also mean over full so if it continues to knock then remove some items until it stops knocking
Jan 03, 2011 | Washing Machines
Knocking in trany during agitate/wash cycle
Probably a bad tranny or bad bearings on the tub.
Mar 12, 2010 | Washing Machines
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Washing machine makes knocking sound
Hi, it sound like your machine overloaded, try smaller wash, and check to see if it does same thing, let me know, if it continues with small wash. good luck.
Aug 08, 2009 | Washing Machines
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Maytag topload washing machine
either you have a bad pressure switch or the latex hose to it or has a hole in it it may have come off either the tub or the switch if it was shaking badly it will be connected to the fill option switch on the control panel go down then hook to tub
Dec 30, 2007 | Washing Machines
Loud Knocking
this is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Sep 18, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
