Question about Technics SA-AX540 Receiver
I have no sound and it reads overload and tells me to turn off power. what do i need to do?
Hi
I have the same problem and a common problem with this model is :
"Technics models are sort of notorious for bad solder connections, especially
at the output IC's and regulator transistors. "
I hope this helps you
Posted on Oct 19, 2009
Screen reads overload
De-energize the machine totally, wait 30 seconds and power it up again. See if the problem clears.
Probably the motor is pulling too much power. If you are not sewing something thick, the machine is binding inside and needs at least an oiling and maybe it needs to be taken in for service.
We can help you better if you tell us the make and model number of the machine.
Mar 02, 2015 | Sewing Machines
Overload comes up on receiver when sound starts what causes this?
too many cables from outlet , use dedicated power source 12 amp
Aug 30, 2014 | Audio Players & Recorders
What does it mean when the "overload" light comes on. I know the train doesn't function, but I don't know why or what the "overload" light is telling me.
It sounds like your are trying to draw too much power from the system. Try to reduce the number of trains on the track. Otherwise, your train might need a bigger power supply.
Oct 06, 2013 | MRC 548B Tech II Trainpower 027 AC...
Overload
that means you are trying to pull way to much power from the receiver and it can not supply the power needed
Jul 16, 2013 | Panasonic SA-HE200 Receiver
My electric amana oven turns off after it has preheated and is baking for a little while. the display goes off and will not turn on until the oven has cooled. is the control board bad?
Ovens have a thermal overload beneath the outer skin which prevents the oven from overheating. If the temperature in the cavity gets too hot the overload will operate and cut all power. When the oven cools down sufficiently the power is then restored. My guess is that this is what is occurring. If the electronic timer is faulty is doesn't normally turn off and on, it just won't work. It sounds as if the thermal overload needs replacing.
Feb 26, 2011 | Amana Ovens
Clicking sound
That is your compressor overload switch, and it's telling you that your compressor is overheated. Sometimes this situation will clear itself up by turning off your fridge for a few hours until the compressor is cool to the touch. This clicking problem can be caused by several things including a worn out compressor, but is often caused by turning the thermostat up and down several times in succession which overloads the compressor.Try letting it cool to the touch and restarting before trying a repair. that may be all you need to do.
Mar 13, 2010 | Refrigerators
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
It just starts and stops after few seconds ...
It sounds like either the compressor is bad, or the overload and relay assembly mounted to the compressor is bad. The easiest way to determine which is to put an amp meter on the power wire to the compressor assembly. It should only read a few amps while running. If it reads excessive amperage, you have a bad compressor. If you do not have an amp meter, then you could just go get a start relay and overload from a parts store and try changing those parts, as they are much cheaper and eaiser than changing the compressor....just unplug it before messinfg around inside the overload cover on the side of the compressor! Good Luck!
Oct 10, 2006 | Bosch Exxcel KSR34423 Refrigerator
DVD power on
I think that there is overloads on that specific socket that you're using try to change the socket. Or see if you have connected the rca cable properly because if the sound is connected to the video of the dvd output it might cause overload on the dvd which makes it turn off for safety reasons. Good luck with it!!
Feb 11, 2006 | Akai DHT300 System
Technics SA-AX540 Receiver Logo
359 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
