Question about Mitsubishi WD-57731 57" Projection HDTV
WD-57731 every 6mos bulb replacement
WD-57731 i have had my tv for about 3 years,bought it brand new,but in that time the first bulb was replaced about 3 days after warranty expired and since that day every 6mos have to buy new bulb is there some other problem burning out these bulbs
  • 63 Answers
You need to make sure you have at least 6 to 8 inches of clearance behind the set. You may also need to replace the balast
Posted on Feb 15, 2010
Third time replacing 65" mitsubishi dlp bulb ?
Use Osram or Phillips bulbs
Check for blocked air flow
Always allow TV to complete cool down with plug in wall
Check/Replace ballast
Aug 22, 2016 | Mitsubishi WD-65638 65" DLP HDTV
My tv mitsubishi wd-60735 turns on for about 2 min. then shuts off and red lamp light turns on,,,The lamp is only 3 months old.. Do I just need to replace bulb again or is it something else???
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Jul 20, 2011 | Mitsubishi WD-60735 Projection Television
Bought 3 bulbs for tv every 1.5 years! why?
You probably have a bad lamp ballast. You should buy one of those off e-bay and replace it.
Jun 16, 2011 | Mitsubishi WD-Y57 57" Projection HDTV
I have a Mitsubishi WD-57734 and the picture when out on it. It's 3 years old and seems logical that the bulb burnt out. We still here the sound. I started looking at replacement bulbs and found other...
U used this tv 3 years?The tv been on and watches like 4 or 5 hours every day?Yes,than the tv projection lamp life is over.Require a new tv projection lamp.U also hear alot of cliking sounds,when tv first turn on?Yes,than the Ballast board is also dead.The Ballast board job is to help to ignite the tv projection lamp.
Nov 16, 2010 | Mitsubishi WD-57734 57" HDTV
On-going problem where tv is turned on and almost immediatley says it will shut down because of an air-flow problem. After turning on several times it used to then work but lately it just repeats the same...
The fan is shorted and might be dead.The projection bulb been in the tv and used for the last 3 years?The projection bulb,life span are over.Require a new projection bulb.
Jul 04, 2010 | Mitsubishi WD-57732 Projection Television
I was watching tv and the tv cut off and the red lamp light came on does it need a new bulb?
Lamp light lit that means lamp is dead and time to replace it.
If lamp has not been replaced in 2-3 years then its time to replace it. Make sure to buy original lamp for TV safety.
Dec 06, 2009 | Mitsubishi WD-57731 57" Projection HDTV
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Tried to replace bulb
Is this the part number you are using?
Mitsubishi 915P020010 Lamp
maybe you need to replace lamp ballast
Mitsubishi 939P978010 Pwb-pwr Lamp Rmd (V26/26++/vk26)
Apr 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blown bulb
time to change the bulb, the bulb doesen't last very long for the price that it cost. I have replaced three in mine in the past three years.
Jul 04, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD 52528 tv
I had the same problem last year - it was, indeed the bulb. At the time the tv was still under warranty and Mitsubishi sent me a replacement bulb.
Dec 27, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-57731 57" Projection HDTV Logo
336 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
