Question about Texas Instruments TI-5019 Calculator
Don't have a manual; have pulled the top off but can't figure out exactly how the paper should go in.
    President:
  • 566 Answers
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Posted on Sep 08, 2009
Paper goes part way in then stops. printer continues to run but paper does not go through
Hello,Follow the steps below:
Step one: Remove any loose paperRemove any loose paper from the input tray.
caution.pngCAUTION:Do not remove jammed paper at this stage.Step two: Clear the jam from the back of the printer
  1. Press the Resume button (c01324470.gif ) on the front panel of the product. If the paper jam does not clear, then follow the remaining instructions.
  2. Press the Power button (c01345237.gif ) to turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Remove the rear access door.Press the handle to the right, and then pull out the door.Figure 1: Remove the rear access doorc01427255.gif
  5. Gently pull the paper out of the rollers.
    caution.pngCAUTION:If the paper tears when removing it from the rollers, then check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollersWhile the rear door is removed from the product, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water.Rotate the rollers with your fingers to clean all the way around.Figure 2: Cleaning the paper rollersc00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear door.Gently push the door forward until it snaps into place.Figure 3: Replace the rear access doorc01427257.gif
Step four: Open the top cover and clear the jam
  1. Raise the top cover of the product.Figure 4: Raise the top coverc01423757.gif
  2. Gently pull the paper out of the rollers.
  3. Lower the top cover.Figure 5: Lower the top coverc01423751.gif
  4. Plug the power cord back into the product.
  5. Press the Power button (c01345237.gif ) to turn the product on.
Step five: Reload paper and test the printerAfter removing any jammed paper, make sure the product is functioning correctly by reloading paper and testing the product.
  1. Raise the output tray.Figure 6: Raise the output trayc01423754.gif
  2. Slide the input tray paper-width guide to the left and load a stack of plain white paper in the input tray.Figure 7: Adjust paper guide and load paperc01423755.gif
  3. Slide the paper-width guide to the right until it rests, snugly, against the stack of paper.
  4. Lower the output tray and pull out the tray extension.Figure 8: Pull out the tray extensionc01423756.gif
  5. Print a diagnostic page.
    1. Press and hold the Power button (c01345237.gif ).
    2. While holding the Power button (c01345237.gif ), press and hold the Cancel button (c01235250.gif ), and then release both buttons.
    3. The product prints a diagnostic page.
    • If the page prints successfully, the issue is resolved.
    • If the issue is not resolved and another jam occurs, continue to the next step.
Step six: Service the printerIf you have completed all the preceding steps and are still experiencing a problem, service the product.Thank You.
Dec 26, 2012 | HP Office Equipment & Supplies
NEED MANUAL FOR EXCALIBUR KINGMASTER II ELECTRONIC CHESS/CHECKERS (911E-2)
Search google for "excalibiur electronics kingmaster manual" The first result should be a manual for KingMaster III? Don't worry, it's almost the exact same thing, and the differences you can figure out.
Feb 13, 2012 | Excalibur Toys
I have an HP 4515 and we are getting black spots on various pages. Is it time to replace the fuser assembly
Put paper in the manual feed tray. Print a few pages. As the paper gets pulled half way into the printer, open the top cover, pull out the toner and look down at the paper. If you see the spots replace the toner. If you don't see the spots replace the fuser.
Nov 22, 2011 | HP P4515n LaserJet Printer
I got the watch at Costco and it was one of the last ones in stock from the display case so it didnt come with a manual. I don't understand exactly hat the buttons on the top and bottom of the main...
you may search online on Google there are many solutions available online for bast clothing that suits your personality you have it on got apparel....
http://www.gotapparel.com
Sep 04, 2011 | Tommy Bahama TB2082 Watch for Women
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Nov 23, 2010 | Xerox Phaser 6180N Laser Printer
I am printing several pages and there is a jam. I
It will re-print it after you clear the jam. Just pull it out pulling slowly and evenly and it will come out.Also you can see directions on HP.com. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 3055 All-In-One Printer
There is paper jammed in the printer - I can see it when I look through the paper tray but cannot reach it to try and pull it through. does the paper tray come out?
paper tary should come out not for sure, I have a Brothers HL-2140 when my printer get a paper jam I have to remove the toner cart, to get the paper out then press the start botton for it to print, Hope this helps you some
Jul 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
I can not figure out where to load photo paper in the paper tray
Do you still have your manual? It should show you exactly what to do. Good Luck! If you don't have your manual ,go to the website for your PC and click on support and you should be able to get help there or even download a new manual.
Jul 26, 2008 | Computers & Internet
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Paper stuck in Brother HL 2040
suggest you see the on-line manual (you may have downloaded it to your pc also as I did). It shows that you can open up the front and the back. If that isn't good enough...
1) if it is wrapped on the back, orange, roller, hold down on the blue 'tabs/levers' on either side of the orange roller to release the pressure so that you can pull it out.
2) you can pull out the toner and look in there (remember to press down on the blue 'tab/lever' before you pull the toner out by grasping it in the middle - the paper may be easier to see/reach that way.
Feb 26, 2008 | Brother HL-2040 Laser Printer
Texas Instruments TI-5019 Calculator Logo
323 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
