Question about Oster 12-Bottle Wine Cellar - Black
THE UNIT IS NOT COOLING AT ALL AND THE FRONT DISPLAY IS NOT SHOWING ALL THE NUMBERS
  • 1 more comment
  • carringtonme Sep 09, 2009
    I DON'T THINK THE UNIT IS LOW ON FREON I THINK THE PC BOARD IS BAD BC NOTHING IS WORKING NOT EVEN THE FAN INSIDE OR IN THE BACK OF THE UNIT
    DID YOU GET MY LAST MESG
    MY 12 BOTTLE WINE REFIGERATOR IS NOT WORKING THE FRONTE DISPLAY IS NOT SHOWING ALL THE NUMBER AND THE FANS INSIDE THE UNIT AND THE FANS THE BACK OF THE UNIT IS NOT WORKING
    Brigadier General:
  • 5,158 Answers
If the display does not show the numbers properly that suggests a problem with the controls. you may be able to reset it by unplugging it for about 10 minutes and plugging it back in.
does the unit make any unusual noises ?
robert
Posted on Sep 09, 2009
  • 691 Answers
Unit can be low on freon or have leak from the unit, more likely the compressor motor is burnt out which happened twice to us. I think they used fairly cheap motors, who's knows. From my experience and hate to say the brand is awful, would not recommend the brand and the products. many consumer complaint of the product, I had two of them my self, good price and not expensive. First one last us 8 month and it quit working, took it back where I purchase it and got another one and though it was a manufacture defect and it too also quit after a year, contact the company no help there, this kind the unit is built to used once when it quit you dump it. Part are imposible to get. you can check out this complaint site, I also made a complaint. Not even worth taking it to local small ac repair, it will cost you have of the price for the new one. better off getting a different brand. www.consumeraffairs.com/homeowners/oster_wine_cooler.html
Posted on Sep 08, 2009
Display window in my comfortstar indoor unit not showing all temp digits, happened after power outage.
Unplug unit from wall for 10 seconds. Plug back in. If no display you likely have a shorted control board.
Jun 12, 2017 | Heating & Cooling
Whirlpool oven AKZ451/IX/01 display has intermittent display. How do I change it?
Open the oven door and look at the underside of the control panel.
Oct 19, 2014 | Whirlpool Ovens
Led display assembly cables do not match my mac
Hi Mario,
Are the part numbers the same? If they are, take photographs showing that and the differences between the cables and send the unit back to where-ever it came from with the photos.
Mar 22, 2013 | Apple 661-5868 Genuine Original Macbook...
I have a up right hoshizaki model fh1-AAC unit will not come out of defrost
These machines do not work like you think. The display will show the defrost mode even when in the freeze cycle. After a defrost cycle, the cooling system comes on but the display will not show any temperature numbers until the conditioned space gets to within 15 degrees of where you have it set to cool to. So, if it is set to 0, the box needs to hit 15 degrees before it shows numbers. You have a cooling problem. Several thing can cause this. may need a tech to check.
Sep 12, 2012 | Hoshizaki Freezers
Numbers not complete on display
If the numbers are faded, dimmed or not even showing, the display control will have to be replaced. Thats the only repair for that issue.
Apr 25, 2012 | LG Dryers
I cant turn it on
Wish you had more of an explanation but here it goes: Check to make sure the outlet has power to it, make sure the gas is turned on, if the display is blank, there is a fuse on the circuit board that may be bad, if the display works but unit does not fire, press the Economy button and the Up and Down arrows all at the same time and hold for 5 seconds. The display will start showing trouble code numbers, have an assistant write the numbers down as they appear. There may be three or four numbers displayed at the same time. You can always do it again to get the numbers. Once you have them, look in the user manual or post the numbers on fixya and we can tell you where to start looking for problems.
Mar 04, 2011 | Rinnai RHFE-556WTA Direct Vent Heater NG...
The numbers on the phone is not showing...or when somebody calling in
Did you mean there is no display, if so the display unit is having the fault . Open and check if the connecting lines are faulty, remove and reset, if not the display is faulty.
If thers is no caller identification on yourr phone(CLIP)/ or the memory is not showing any numbers, then it is possible that the sub controller IC/memory is defective.
Best to do is to open and solder this section for any moisture, sweat/water. Look for any clogging of dirt, clean ,touch up solder with care not to bridge any circuits.If this wont help the IC must be defective and it might not be very economical to change with the cost of a new one.
Hope you decide with this tip
Aug 22, 2010 | General Electric 25952EE3 Cordless Phone
Front Display and contacts
you should replaced the LCD to correct this issue
Apr 18, 2009 | Motorola Mobility RAZR V3
Led display not showing fill numbers
Pretty common problem in this vintage Audi. There are place that will repair the bad display unit on your control panel. Check out some of the Audi forums on line.
Aug 13, 2008 | 1999 Audi A6
Oster 12-Bottle Wine Cellar - Black Logo
136 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you an Oster Furniture Expert? Answer questions, earn points and help others
