Question about Panasonic DMR-E55 DVD Recorder
My panasonic dmr-e55 wont power up at all. i had it apart, i checked the fuse, and the connections, and it still wont work. PLEASE HELP
    Problem Solver:
  • 17 Answers
I had the same problem with my DMR-E55 over the weekend. I looked at similar problems and solutions for the DMR-E85 on this website. If you open the case, look for two capacitors that may have a bulging top end and a yellow/gold substance leaking out. If you see that, you have the same failed capacitor problem. Usually both will have failed, but the problem may only be noticeable on one. Replace both the C1260 and the C1261 while you are doing the work. Use the next larger uF and V ratings with both wires coming out of the end of the capacitor. Note the +/- polarity on the existing and new capacitors. Look at other solutions for similar DVRs on this website and club.cdfreaks.com I will try to post my photos on a photo-sharing website tomorrow. I will post a link here after I upload them.
Posted on Sep 09, 2009
Testimonial: "great idea! but where do i get the capacitors?"
  • Jenn Ellis Nov 23, 2009
    I found the capacitors that I used at Radio Shack. Remember that you can use ones with larger uF and V ratings than were provided with the original equipment.
I can't power on my dvd recorder dmr-e55
No power light look for a fuse--power light comes on and then goes out look for either a jammed mechanism or a power supply problem.
Apr 22, 2012 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-EZ48V keeps blowing fuses.
I don';t like to replace fuses with the power on. the fuse is meant to protect valuable parts; this error mode indicates a probable fault internnaly. NEEDS to be serviced.
Apr 07, 2012 | Panasonic DMR-E55 DVD Recorder
Got a panasonic dvd recorder.dmr e55. need instructions to connect to television. have no manual. would like help to do this.
You may be able to download a free pdf copy of the manual online from the following site:
http://www.retrevo.com/support/Panasonic-DMR-E55-DVD-Players-manual/id/312dj185/t/2/
(just follow the prompts)
Pages 6 - 9 of the manual show connection of this unit to a TV and/or other equipment in some detail.
Apr 26, 2011 | Panasonic DMR-E55 DVD Recorder
Panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Jan 22, 2009 | Panasonic DMR-E55 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Pioneer dvr-420h
Could be a blown internal fuse or a fault on the power supply board. If you can check these things yourself look towards a voltage regulator as the main culprit. Good luck.
Sep 20, 2008 | Panasonic DMR-E55 DVD Recorder
DMR E55-P will not read DVD-R
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Mar 02, 2008 | Panasonic DMR-E55 DVD Recorder
Please help me with the set up of two Panasonic DVD recorders
To record and veiw DVD movie at the same time connect the DMRE55 RCA cable output to DMREZ25 input 1 then the DMREZ output to yout TV input. Then on the DMREZ press input select and select IN1 to record from the E55.
Nov 04, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic dvd video recorder dmr-e55 user manual
http://service.us.panasonic.com/OPERMANPDF/DMRE55.PDF
Oct 13, 2007 | GoVideo Home Audio&Video: Go-Video DVD...
Panasonic DMR-E55 DVD Recorder Problem
I have been told that panasonic now have a faster speed disc on sale to suit the newer dvd recorders that dmr-e55 cannot record on as they are too fast. You have to buy the slower speed ram discs to suit the dmr-e55.
Aug 26, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
1,241 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
