Question about Linksys Wireless-G WRT54G Router
Wep code how do i disable a wep code or even just find out what it is so i can acces the internet via laptop
  • 556 Answers
WEP code is a password configured into both your network router / access point and network adapter. It is intended to prevent others that do not know the password from using your wireless connection. It also encrypts your wireless to limit what someone can intercept when monitoring your wireless communications. Use your User Guides for the router and wireless adapter to determine how to disable the wep features. They are relatively easy to find in you follow the respective user guides in most cases.
Posted on Dec 09, 2007
Blackberry 9300 koodo WEP codes
To connect to your wireless router you need the wireless router's WEP or WPA or WPA2 encryption code.
To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Feb 24, 2012 | RIM Cell Phones
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
Just hooked up a router but i can t get connected with my laptop because system is "secured" I need to change settings to unsecured
Access the router embeded web server and turn off the WEP KEY under Internet wireless security.
You can acces the EWS by entering the router default gateway on internet explorer
Aug 24, 2010 | Computers & Internet
The wireless network is broadcasting but it will
Howdy,
Sounds like you may have an encryption problem. Are you running an open or secure network? Try setting it to Security > Disabled and see if you can get on. (Please note where you were before you disable the security) This will be under the Wireless > Wireless Security tab. If you can connect after disabling the security then you probably did not enter you key code correctly. OR... You may have set it to a level of encryption that your wireless laptop does not support. (Don't know the age of the laptop - some older ones will support WEP only and "b" only.) Make sure that you are broadcasting in both "b" & "g" ranges and if WPA won't work for you, then try WEP. It is a little difficult for me to tell you exactly what to do because I do not have all the necessary information but perhaps this will help. The main thing is to disable the security first and see if you can connect. If you can, then this is a BIG clue and good news. Then you know it is an encryption issue.
Typically the encryption choices are WPA - WPA-PSK - WPA2 - WPA2-PSK - RADIUS & WEP. I would recommend WPA-PSK with TKIP for normal "modern" applications. If your WRTP54G has the Auto Security setup button on the front of the router you may want to use it to automatically set up your wireless security. You can tell by feeling the raised rectangular push button on the front panel.
Good Luck!
J
Jun 12, 2009 | Linksys Wireless-G WRTP54G Router
Hi, I am trying to connect another laptop to our wifi but when i enter the netgear pass code it does not regonise it. Any ideas?
The router's passcode is a different thing to the WEP/WPA encryption code.
Type www.routerlogin.com into the internet browser of a computer that has access to the router and disable the WEP/WPA encryption, and press Apply or Submit.
Now Enable it again and it'll ask you to choose a password. Put something in and Submit that. That password is what you would put into the other laptop to connect.
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | D-Link DI 514 Wireless Router (DI-514)
Cannot connect to internet via wlan but can lan
The only thing that seems to be missing here is did you try another wireless card? If its built in you can get a usb wifi or pcmcia type. That will probably get you back online via wifi.
Dec 15, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Wirless conection on mac
means no connection to your computer. Mac helpsite and your adsl company can help you by phone to set this up
Apr 20, 2008 | Computers & Internet
Laptop
you need a WEP key i'm guessing you're trying to say. go to a browser, type in the address bar http://192.168.0.1 and then login. the defult login name is either user or admin. the defulte password is either password or 12345. after logging in, find the menu that says wireless. from there you can either disable the WEP key, or write down the WEP key and type that into your laptop when it tries to connect. disabling the WEP key brings down your internet local security, but is not a problem is you don't live too close to anyone
Jan 19, 2008 | Computers & Internet
Wep/wpa
Hi, doesn't really matter which, what is important is what ever it is you choose, it should be the same/consistent all through out the wireless network/system. example, if you choose wep $ key is 12345 in your router/AP, then all you wifi clients should be using wep $ key of 12345. Choosing or not choosing what wireless security mode to use is not preventing you to log unto the internet, they are designed that you can securely communicate/acces the router/ap and if granted acces, the router/ap will then be your gateway, so first you must be connected/logged on to the router/ap before you can share its internet. Hope this be of some help/ pls post again how things turn up. Kind regards.
May 21, 2007 | Belkin Wireless Pre-N (F5D8230-4) Router...
Linksys Wireless-G WRT54G Router Logo
90 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
