Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Massey Ferg 28 stalling
I have an old massey Feerg 28 (1953 according to date on starter motor. It had been sitting for about a year without going. Have cleaned out fuel tank, tap, bowl, new plugs, leads etc. Thing starts ok and drives.
However, when throttle opened up in 4th gear it dies and conks out. A friend suggested air getting sucked in above carb so gasket replaced. I haven't fiddled with mixture settings as don't want to make things worse as I don't kniow what I'm doing !! Any suggestions as to what to try next?
  • Dave harlock Sep 09, 2009
    I haven't troed the choke but will do that asap. I've cleaned out the carb and got rid of the gummy residue from months sitting around. Afetr it conks out, I can reduce the throttle and it starts again easily enough.
  • dieseldod May 11, 2010
    whats happens if the choke is applied slightly when its about to conk out? Have you stripped and cleaned the carb? there may be a piece of debris floating around and blocking the jets when the engine is demanding loads of fuel. does it start easy or difficult after its conked out ?
    Brigadier General:
  • 5,158 Answers
Although you have basically changed the fuel in the system i would suggest a bottle or half bottle of gas line anti-freeze in the next couple tanks of gas it will absorb any water in the system. there are also some after market fluids that you may want to try. i believe one is called "gum out". after a year (or less) gas tends to "gum" up and restrict fuel flow.
you should see results almost immediately. if there is a vacuum leak you will hear a hissing noise.
robert
Posted on Sep 08, 2009
Testimonial: "super quick and something I hadn't thought of. Will give that a go. Thanks very much"
I have a Massey Ferguson tractor serial number 9A89879 I would like to know what model it is and what year it is
I cant give you an exact date but it is from the early 70s. That is when they were yellow. My educated guess on this is 1973. If you go to a Massey Ferguson dealer with your numbers they will gladly tell you what year it is exactly.
Jan 27, 2016 | Toys
Can't find the year of my tractor, serial #PGA19781. Any info will be app
Hi Casey,
Get in touch with Massey Harris customer support department.
You could also try. Massey Harris Tractor Collector Web Site
Aug 08, 2015 | Garden
Massey ferguson tractor wont start, starter wont even turn over
check your ground to the starter, if thats ok try tapping on the outside of starter body while trying to start engine, the starter may have a dead short in it
Feb 14, 2015 | RTO Massey-Ferguson Tractor TE20, TO20,...
Need a service manual Massey-Ferguson 135
This store seems to have tons of Massey manuals and some for the 135 tractor: Massey Ferguson Manuals
Jul 02, 2013 | A&I Products A-509057M91,Massey...
Massey fergason temp gauge diagram
Really is simple, wire comes from sender and connects at gauge. Some older tractors did not have gauges and even the holes for them had to be cut out of the dash face. Sensor wires were bimetal conduits and just transferred heat from motor to dash.
Jan 02, 2012 | RTO Massey-Ferguson Tractor TE20, TO20,...
Massey Ferg 24 won't start. Spark to plugs, firing order checked and plenty of new fuel in a new line. Carb pulled apart and jets etc all cleaned out. When turning over there is loads of suction on air...
I can't get the compreshion right on new sleeves, pistons and rings in my Massey Ferguson T20. I get about 35-60 when checking compreshion. I have taken them out twice and checked to make sure the rings are in correctly, etc. Your tips are greatly appreciated.
Mar 01, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
What sort of oil is used in the gearbox of a massey ferguson 28 Te 20
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
Apr 29, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
Diesel getting in to sump on massey 3080 year 89
well its most likley to be the piston rings worn out there is a slght chance its a blown head gasket or duff injectors but im going to put my money on rings
long old job fixing this,, but at least you can get a set of piston and liners for it,,,
Oct 25, 2009 | Spec Cast 1: 16 Massey Ferguson 98 Tractor...
What years is my tractor?
google Massey ferguson the model number will be on the motor
Aug 30, 2009 | 2004 Jeep Liberty
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
370 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
