Question about Rex RX-1804
My bobbin thread won't draw up either... - Rex RX-1804
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
my bobbin thread won't draw up either... - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 10, 2009
I received a 221 singer feather light as a gift.... Love using old machines. It will not pick up the bobbin thread. When it cycles the top thread hangs up and breaks.
Lucky you!
First thing to always try is a brand new needle. A lot of sewing machine problems are due to an old, dull, bent needle.
Most likely the machine has been knocked out of time--the needle and hook are out of sync. Search for sewing machine timing or take it or service.
https://singer-featherweight.com/blogs/schoolhouse/how-to-thread-a-singer-featherweight
Dec 12, 2017 | Singer Sewing Machines
The needle with top thread couldn't draw the bottom thread from the bobbin to ready the machine for sewing
Are you saying that the upper thread is not pulling the bobbin thread up to the top?
Install a brand new needle.
Remove the thread. RAISE the presser foot and rethread from the beginning--allows the thread to seat completely in the upper tension disk.
Check that the bobbin thread is inserted in the bobbin case facing the correct direction and that the bobbin case is threaded correctly through the bobbin case tension. Be sure to leave at least a 6" tail of thread on both the upper and lower threads.
Retest.
If it is still not picking up the bobbin thread, the bobbin case may be defective/malfunctioning or your machine probably needs professional service.
Feb 27, 2016 | Sewing Machines
Won't catch bobbin thread
hi Shauna.
this is all i could find out from the internet.
Make sure the presser foot is up when seating the thread through the upper tension. Now, it's time to draw up your bobbin thread. Turn the hand wheel (TOWARDS YOU ONLY, never turn the hand wheel away from you) and hold the needle thread lightly. Tug on it as the needle goes down and then comes up again.
if this is off no help to you go to this link and see if its any good to you.
Frequently Asked Questions Singer Sewing
or this one.
Sewing Machines Won catch bobbin thread Google Search
Dec 13, 2017 | Sewing Machines
Help! I'm having problems with my Necchi Lydia 3. Firstly when threading up, the threaded needle refuses to draw up the bobbin thread. I've followed the instructions and the needle comes in and out but...
try a different bobbin
make sure the bobbin in turned the right way in the bobbin case
also the machine may have a timing problem, and having it checked to would be a good idea.
Sep 07, 2013 | Necchi 4575 Mechanical Sewing Machine
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Dec 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Needle Thread and Bobbin Thread
This is a timing problem and will have to be repaired by authorized dealer.
Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
Bobbin
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Nov 06, 2006 | Rex RX-1804
Rex RX-1804 Logo
228 people viewed this question
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
Murielle Dumas
Level 1 Expert
Joseph Mueller
Joseph Mueller
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
