Question about KitchenAid KHMS147 Microwave Oven
Broken handle on Spacemaker microwave
The handle on my Spacemaker microwave, model # JVM140J003, is broken. Can I get a new handle? How do I access the inside of the door to replace it? I know it's an older model (1991), but it works great and I see no need to replace the whole thing!
  • 5,911 Answers
The handle can be replaced without replacing the entire door, or oven. The part number is WB15X1309 and can be purchased at pcappliancerepair.com for about $45. Due to the age of your oven, I could only find it at a couple of web sites, and this was the cheapest price I could find for you.
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Posted on Sep 08, 2009
Testimonial: "Thanks a million for your speedy and detailed info ! I'll get the part and do it myself."
Handle broken
I need to replace handle which fell off. Whenre do I find handle> Do not have model #
Nov 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on my GE spacemaker xl 1400 microwave is broken (plastic). How do I fix this.
By replacing with new one for sure... You can find them on amazon, here: Amazon com ge spacemaker xl handle. I hope this was helpful. Cheers
Nov 14, 2010 | GE Spacemaker JVM1740 Microwave Oven
Our GE Profile spacemaker 2.0 handle is broken. How can I change it?
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you
May 31, 2010 | GE Profile Spacemaker Over-the-Range...
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Broken handle on GE Spacemaker XL1800 microwave
New handles for microwaves can be bought on amazon. Take a look here Amazon com microwave handle and choose one (which fits). P.S. watch out on reviews and handle sizes. I hope this was helpful. cheers
Sep 07, 2008 | GE JVM1851BD 1100 Watts Microwave Oven
Another broken handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KHMS147 Microwave Oven Logo
350 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
