Question about Power Acoustik Pcnc3.0f 5 Farad Digital Power Stiffening Capacitor
Power acoustik 5 farad neon digital capacitor
Witch is battery in and witch is battery out
    Scholar:
  • 95 Answers
You hook it up in parallel with your amp. You'll see a and - on the clear plastic cover.
Hook a wire from your amp or positive to the capacitor
Hook another wire from your amp - or negative to the - on the capacitor.
That's it, you're done.
If the plastic cover is missing, or painted over, with the neon tubes at the top, and the connector/display end facing you, the right side is the left side is -.
Posted on Aug 29, 2010
?what is a capacitor?
A device used to store an electric charge, consisting of one or more pairs of conductors separated by an insulator.
Apr 17, 2016 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Capacitor on induction blower
How many uf is indicated on the capacitor.It will show a number ie 10uf. If the rating on the capacitor is more than 5uf or less than 3 uf then the capacitor is failing. 10% variance is acceptable. Most electrical wholesalers sell capacitors and cost is around $20.00 or so.
Mar 26, 2013 | Power Acoustik Pcnc3.0f 5 Farad Digital...
I have a PCX-5F POWER ACOUSTIK 5-Farad Digital Capacitor and after i turn the car off it stays on and sometimes when the keys not even in the ignition the cap stay on. why is it doing that?
It is a capacitor. Please read up on how capacitors work and it will explain itself.
The capacitor is holding a charge, just like it was designed to do.
Oct 01, 2012 | Power Acoustik Pcx-5F 5-Farad Digital...
How am I going to connect it to my car,Im wondering why it doesnt have a remote terminal like what the other capacitor brand had.
it's like a battery. you run it in parallel (run power from battery + to capacitor + then from capacitor + to ampplifier +) battery, capacitor, and amp each has its own ground (black or -). you don't need a remote wire. it only stores electricity until the amplifier needs extra juice (so your headlights won't dim).
Jul 24, 2011 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Como va conectada la corriente y la tiera al capacitor
Del corriente de la bateria al positivo del capacitior. De la tiera de capacitor al positivo o corriente del amplificador. Bueana suerte.
Feb 14, 2011 | Power Acoustik Pcnc3.0f 5 Farad Digital...
How to wire a 10 farad power acoustik capaciter
With BIG wires from battery to cap and then to your amp.
Good idea to put fuse or fusible link between bat + and the cap. Protects against fires.
If one wanted to be safe from starter motor transients I would gate the + power lead with a power relay between the battery and the cap. This relay should close when you are in run or accessory position of your key switch. I recommend this as there are so MANY dead car audio amps. Just search for them on here! A bunch of them MIGHT be caused by inductive transients during starter motor shutdown. Note the inductance is in the grounding wire from teh battery to the engine/chassis.
Jan 23, 2010 | Power Acoustik PCX10F POWER ACOUSTIK 10...
25 farad cap slowly losing its charg if the car sits for to long
Cap is hooked up wrong, should shut off after a certain amount of time and reactivate with the ignition hot wire. If it's draining your battery continuously then you should look at the wiring.
Dec 24, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Need diagram to install capacitor
Hello tommysgirl,
Here's a link to Car Audio Help's cap wiring diagram.
Hope this helps.
Aug 27, 2009 | Power Acoustik 1.2 Farad Capacitor Pcnc...
Cant figure out how to wire a power acoustik 5 farad power cap.
Use to independent grounds always better that way. Better full field for power and less distortion. I like to use 4 guage or lower like 0 guage for high powered systems. Good luck, thanks for using FIX YA
Jan 09, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Power Acoustik Pcnc3.0f 5 Farad Digital Power Stiffening Capacitor Logo
1,368 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
