Question about Kenmore Elite 45986 Front Load Washer
I need to replace the clutch,and lid switch - Kenmore Elite 45986 Front Load Washer
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
My washer is not spinning
Hello there and thank you for choosing fixya
Normally this problem is due to a worn out drive /basket clutch assembly that has failed this assy is normally should be replaced as a set and not only 1 part because if you only replace the drive but not the clutch then the clutch will soon fail ok so i suggest replacing them as a set
Here is some more info on this below
Quick tips....Slow or no spin....
  1. Lid open.
  2. Lid switch defective. ( Very Common problem )
  3. Lid switch disconnect plug open/burnt.
  4. Clothes between basket and outer tank.
  5. Lint filter caught between the wash basket and outer holding tank.
  6. Wiring harness.
  7. Bad motor capacitor ( How to check )
  8. Weak clutch.
  9. Timer switches. ( possible not allowing the pause required for the transmission to set up to spin )
  10. Motor.
  11. Cam driver on basket drive broken or basket drive weak.
  12. Spin tube.
  13. Notches in drive block worn out and not engaging basket drive shaft.
  14. Broken motor coupling. See Replacing Motor Coupler Page
  15. Read a bit on how the washer works as well.
If your washer will not spin...first thing is to consider if washer is RUNNING and not spinning or NOT RUNNING and not spinning. If the washer is NOT running ( or working intermittently ) check lid switch for continuity. Broken lid switch arm and the lid switch probe should be checked as well. Something NEW to check for when looking at that lid switch. Always a good idea to check for clothing between the tanks as well. Make sure nothing has gone through one of the inner basket holes and is now scrapping or jamming the tub from moving, such items may be a nail, pin, bra under wire.
If washer IS running, remove power and remove cabinet. Use a piece of insulated wire to by-pass the lid switch wires, turn the timer to spin and pull out the knob, push the knob back in and pull it out again. Watch for the clutch drum to turn ( brown section in picture A ). If it is turning but the inner wash tub is not, then more often than not you have a worn clutch lining or a weak spin spring, also the brake may have seized up. If the clutch drum is not turning and washer is not spinning, often the failure is in the transmission gear box. ( see picture B ).
Apr 29, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Untilmate care II Quiet Wash - Mod # LSQ9200PQ0: Spotaically does not engage in Hi Spin after drain. Motor is running, but basket is not engaged. If you raise the lid (and see that it is not...
The problem is commonly attributed to either a loose/defective lid switch, or a worn clutch/brake assembly.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid switch on the model number you provided is located near the left lid hinge under the console. It is listed as item number 11 under the "Top and Cabinet" parts listing at the websites I provided you. The part number is 8318084. Prices will vary between sites so shop and compare.
The brake/clutch can become worn and the small brake pads will glaze or wear down to the point that it will no longer engage properly and slip. The brake/clutch assembly comes as a complete kit and can be replaced by following the steps provided in this link:
http://www.fixya.com/support/r4249301-replacing_clutch_whirlpool_top_loader
There are helpful exploded view parts illustrations to assist you at the first three website I have listed. The complete clutch assembly is listed as item number 5 under the "Brake, Clutch, Gearcase, Motor and Pump" parts listing. The part number is 285785.
If you have questions, or need additional assistance, please post back and let me know. These are simple repairs that you can easily perform without the assistance of a repairman.
If you have any questions, please post back and let me know. I hope this helps you.
Dec 16, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitate
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Feb 06, 2010 | Washing Machines
Will not wash after catches water,all i hear is a buzzing sound
Jan 22, 2010 | Kenmore Washing Machines
Hotpoint 9533 the wash machine dosen't wash
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Jan 17, 2010 | Washing Machines
Kenmore Model 110-24632300 filled up with water and now will not agitate or drain.
Jan 03, 2010 | Kenmore 22642 Top Load Washer
Washing machine fills with water and will not go to next cycle
Jan 03, 2010 | Whirlpool Washing Machines
T want wash or spin but it will fill up with water and drain
It sounds as if your lid safety switch has failed due to the fact that the unit will fill with the lid open and will not wash or spin. You can listen for an audible click from the micro-switch just as the lid either opens or closes. If you do not hear the click then the micro-switch has failed. If you do hear a click you still can have a bad switch due to the failure of internal contacts in the switch. If you a handy man you can lift the top assy by grabbing it firmly in the front pulling toward yourself and upward at the same time. Sometimes this method will not work and you will have to locate the 2 retaining clips that can be unlatched where the top and the chassis body meet approximately 6 inches from either side. i.e. (2 ea) Using a puddy knife gently press inward on the face of the clip between top and chassis while pulling upward and the clip should release. Do the same for the 2nd clip. Make sure the unit is unplugged, locate the lid saftety switch and test for continutiy lid closed and no continutiy lid open. If there is no continuity in either position the switch has failed and will need replaced.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The agitator in my kenmore elite washer won't agitate. The water won't spin out. The basket turns, and we've had the clutch replaced. Any suggestions?
Jan 01, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Wbsr3140dw will not agitate
There are 2 region of having this problem -
First of all you can check the Lid switch -
then you check the Clutch -
If your washer was made by GE, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it.
Thanks
Sep 19, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
